06-22-2022, 06:42 PM | #15 |
Drives: 22 ZL1 1LE A10 Join Date: Feb 2022
lol says right in the manual to swap to a high temp fluid for track days from GM! 595º plus in my manual. the GM stuff wont cut it. and no, you cant void a warranty! you can only get claims denied. if you have a brake failure and the dealer says its your fault, im sure showing GM what you used, how, and when, they will approve the claim and make the dealer do the work. im not sure what will fail, mostly it'll be caliper piston seals that melt but thats on you and wont be under warranty anyways.
06-22-2022, 06:52 PM | #16 | |
06-22-2022, 06:56 PM | #17 |
never heard of it but makes no sense. if i tune the motor my radio cant be denied as a claim. HP does nothing to speakers or the infotainment.
06-22-2022, 08:21 PM | #18 |
BLUPRINT_1LE
Drives: 2022 Rapid Blue SS 1LE Join Date: May 2017
Yup, looks like I will be doing it myself this time around which is no problem I was being lazy but hey I learned something just like everything else, don’t trust dealership unless it’s warranty item lol
2022 Camaro SS 1LE | PDR | Rapid Blue | Manual | Katech Built SS 1LE | Katech Build Sheet
IG: BLUPRINT_1LE YT: BLUPRINT_1LE ---------------------------------------------------------------- |
06-22-2022, 09:43 PM | #19 |
air compressor bleeder kit and fill bottle make it a breeze!
06-22-2022, 09:58 PM | #20 |
Shadow Gray '19 ZLE M6
I'm a big fan of the Motive Power Bleeder as another option
PPF | Paint Correction | ZL1 Addons Rock Guards | ZL1 Addons Lift Pads | ZL1 Addons Feather Lite Tow Hook | JWM Smoked Sidemarkers | Wildhammer Smoked Rear Reflectors | JWM License Plate LEDs | RotoFab CAI | ADM IC Reservoir v2 | BC Forged RZ05 | SPL Toe Arms | BW Brake Deflectors | CMS Roll Bar | Schroth Profi II ASM Harnesses . Sold: '99 Trans Am (bolt-ons & cam) | '00 WS6 (bolt-ons, heads, cam, 12 bolt) | '05 CTS-V (bolt-ons, short throw) | '10 SS/RS M6 (short throw, CAI, coilovers, LTs, catback, JRE tune) | '01 WS6 YouTube |
06-22-2022, 10:39 PM | #21 |
Drives: 2SS 1LE Join Date: Oct 2011
No, it doesn't. DOT 3, DOT 4 and DOT 5.1 are all chemically compatible. I bled my Hope brakes with my left-over RBF 660.
2018 2SS 1LE 2023 Colorado ZR2 2022 Stinger GT-line AWD |
06-22-2022, 10:42 PM | #22 |
What I meant is the dealership can (incorrectly) say "there is no reason for you to go aftermarket, because your factory fill is DOT4 already, we will not honor the warranty if you do so".
06-23-2022, 01:56 PM | #23 |
Tri-County Camaro SWFL
Have you talked with a different dealer? ...because thats a huge load of bs. Using a different analogy.... if you don't change your motor oil with Mobil 1 and use an ac delco filter, that means your engine warranty will be voided as well..... according to this dealer?
06-24-2022, 07:00 AM | #24 | |
06-25-2022, 01:58 AM | #25 | |
Drives: Jaguar Join Date: Feb 2022
You didn't even mention brake pads and other things, but I use Carbotech 1521 (low dust) on street and switch to Carbotech XP8/XP10 combo for the track. Also, brake cooling rings only apply to Z51; GS/Z06 don't use them. Thump UP to Amazon Price Match
06-29-2022, 11:11 AM | #26 | |
BLUPRINT_1LE
Also a quick update for everyone reading, The dealer called me back 2 days later and the Service manager had their "Warranty Manager" on the phone with me and apologize for the mishap and said they can do the procedure but I told them too late you already pissed me off so I'll do it myself. They explain the staff should've been knowledgeable but I'm like its not rocket science. I just completed it recently and it wasn't as bad as I thought. It just took 2 hours of my time. I decided to choose a different fluid this time around as well and I am using BREMBO HTC64 now since it came in on time. The Pedal is stiff how I like it & Clutch feels good too. I should be well equipped now for the upcoming track day. So far the things I've done: Track Alignment Changed Engine Oil Changed Brake Fluid Changed Rear Diff Fluid Pending Item: Transmission Fluid Change. I dont think I will do this yet since the gears feel fine so far when I am rowing them.
IG: BLUPRINT_1LE YT: BLUPRINT_1LE ---------------------------------------------------------------- Last edited by Blackmonba6Gen; 06-29-2022 at 01:03 PM. |
06-29-2022, 03:57 PM | #27 | |
if you're changing the trans fluid, im guessing you have a manual? |
06-29-2022, 06:21 PM | #28 | |
BLUPRINT_1LE
My neighbor is a tech and I can get his laptop & the details on what to do to replace the fluid. However there is plenty of Youtube video of people showing how to do it too when it comes to trans fluid.
IG: BLUPRINT_1LE YT: BLUPRINT_1LE ---------------------------------------------------------------- Last edited by Blackmonba6Gen; 06-29-2022 at 09:33 PM. |
Thread Tools | |
