Old 06-10-2022, 08:29 AM   #1
SOCAL.M6.ZLE
Having FUN in the SUN...
SOCAL.M6.ZLE's Avatar
Drives: 2022 M6 ZL1 1LE
BEST EXPANSION TANK
Hey guys, i see ALOT of options for underhood expansion tanks in size, location, material, etc... I was curious which you all think is the most effective?
at 2 gallons... and in the fender.... this one seems like a great option?
https://synergymotorsports.com/produ...ion-water-tank
https://dedicatedmotorsports.com/ZL1-2GAL/
This is going to be added to my phase.2 build of cam + ported blower + lower pulley + 103tb + big Gulp
Also, has anyone considered re-purposing the windshield washer fluid tank for this?
2022 M6 ZLE: Katech CNC Ported Blower + Ported Heads + 103mm TB + Oil Pump + C5R Chain + Valve Covers + Coil Relocation
TSP VVT and DoD Delete Covers + LME Chain Guide + DSX Billet Lid + ATI Damper + 9.17" Lower + 2.4" Upper + MM Wild CC
Coated ARH + AWE Touring + Magnaflow Center X + E85 + MSD Coils + Banks iDash + JMS Booster + Synergy Fender Tank
ALL the RED Rear End BMR Goodies + JRE Terminator Cam Package + Remote Tuning and Moral Support from TED @ JRE
BMR Motor Mounts + DMS Front HX + FIC 30's + APEX SM.10's + 305/345 R888R's = 770rwhp 785rwtq @E50 13.5psi
Old 06-10-2022, 08:44 AM   #2
JSH
JSH's Avatar
Drives: '20 ZLE
Mine is going in the trunk.
'20 ZL1 1LE A10,
OEM short block, LME heads/valve train, E2650.
100+ octanes, no eth, no meth, no N2O.
2/23 - 1031/1004 wheel.
4/23 - 1.41/9.61/145 at DA 7000 ft. (only made five passes).
2/24 - LME 390, E2650, FBO, 100 oct.; 1116hp/ 1063tq; 109 oct. dyno next.
Old 06-10-2022, 09:17 AM   #3
ZL1Atlanta
ZL1Atlanta's Avatar
Drives: 2017 Chevrolet Camaro ZL1
I suggest a trunk tank. Higher capacity and typically easier to fill/drain if you want to ice the car down. Keeping what you want to be cool water away from the engine is also good.
2017 ZL1 - PB 8.05 @ 172 MPH @ 3730 lbs @ 70 DA (work in progress)
Built by Vengeance Racing, tuned by Elite Tuned
ZL1Atlanta is offline   Reply With Quote
Old 06-10-2022, 06:18 PM   #4
SOCAL.M6.ZLE
Makes sense... I's like to stick with a smaller one under the hood (less weight) and I dont plan to crank the boost that high... anyone have the fender mount version with install photos?
Old 06-10-2022, 06:28 PM   #5
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
Cordes has about a 2-gallon, underhood tank that goes below the hood latch that seems to be a good option.
'20 ZL1 Black "Fury"
Old 06-10-2022, 06:43 PM   #6
SOCAL.M6.ZLE
I saw that one also... but it looks like you need to cut a large whole to access the lid... which i didnt like... :(
Old 06-10-2022, 09:33 PM   #7
Camaro1973
Camaro1973's Avatar
Drives: 2019 ZL1
I have the dedicated motorsports fender tank. Nice tank, fits right behind the fender, connected to my IC. Just need to drill one of the holes, i can't remember which one, but install is a piece of cake.
LME 377 LT4 Short Block | Magnuson 2650 80mm upper w/13% lower (9.06) | DSX Lid & Valve Covers | CSP Custom Cam w/32% fuel lobe | CID Heads | NW 103mm TB | Roto Fab Big Gulp | CSP 2" Headers w/Green GESI Gen 2 Cats | Borla 3" Full Cat Back w/ S-Type| Mighty Mouse Wild Catch Can| Custom Holley Low side Fuel system| TooHigh PSI Port Injection w/Holley Controller | Forced Inductions Interchiller w/2 gallon fender tank | TK Performance built 10L90
Old 06-10-2022, 09:50 PM   #8
Evansa22
Evansa22's Avatar
Drives: HBM ZLE
This is the adm tank
Old 06-10-2022, 10:46 PM   #9
Mac7504
Mac7504's Avatar
Drives: 2003 Monte Carlo SS SLP, 2022 ZL1
What is the capacity of the adm tank? From what I've read it's not much and doesn't help much at all..
What is your take and do you have data?
Mac7504 is offline   Reply With Quote
Old 06-10-2022, 11:39 PM   #10
Evansa22
Evansa22's Avatar
Drives: HBM ZLE
No data right now, its the larger tank but I got it mostly to deal with any air in the system. Not so much extra capacity because its not even a gallon. Does what i need it to do, Just throwing another option out there
Old 06-11-2022, 12:14 AM   #11
Camaro1973
Camaro1973's Avatar
Drives: 2019 ZL1
It’s really to make filling easier. Holds maybe half a quart at most.
Old 06-11-2022, 09:51 AM   #12
SOCAL.M6.ZLE
Do you have any install photos?
Old 06-11-2022, 10:18 AM   #13
Vigilante375
Drives: 2018 Camaro ZL1
I use it and haven't noticed any heat soak or power loss while going around a road course in 90+ temp days with humidity in South Carolina.
Though I'm stock but still running at WOT around a road course for 20 minutes takes a toll on any vehicle.
This is useful in keeping the air bubbles out of the lines.
Old 06-11-2022, 10:56 AM   #14
SOCAL.M6.ZLE
Looking CLEAN!
Cant wait to hear your beast!!!
When can you make it out to Escondido Cars and Coffee?
