06-02-2022, 12:24 PM | #1 |
Header clearance/exhaust rattle
Anyone running 2” headers have issue with them vibrating on the metal crossmember? Mine seems to rattle against it when decelerating and around 2K rpm’s. Everything they on the exhaust seems tight and it’s the only thing I can think of that would be causing the noise. Or does anyone else have any ideas of what it could be? Thanks for the help!
06-02-2022, 03:58 PM | #2 |
Drives: '86 IROC-Z '18 ZL1 Join Date: Jul 2019
What brand? And how many miles you got? Wo der if a motor mount is going bad.
06-02-2022, 08:49 PM | #3 |
Drives: 2018 ZLE Join Date: Nov 2021
Iv'e got TSP 2" on mine and the only contact it makes is barely grazing the steering shaft bolt. I need to pull it and grind off the threads that are sticking out by about a MM to get clearance. It is real close to the subframe and but doesn't quite touch.
06-02-2022, 09:32 PM | #4 |
Drives: 2020 Zl1 A10 Riverside Blue Join Date: Mar 2020
I have 2" ARH and no rattling
06-02-2022, 09:39 PM | #5 | |
https://shop.halosupercars.com/produ...1&categoryId=7 http://m.bmrsuspension.com/?page=pro...D6943AB9103C78 https://www.bmrsuspension.com/sitear...all/DTB005.pdf
06-02-2022, 10:16 PM | #6 |
They are texas speed. Car has 27.5K miles on it. I guess I need to get under it again and double check all the exhaust hardware. I also thought maybe a motor mount has gone bad but with under 28K miles it seemed unlikely.
