05-28-2022, 11:52 PM | #1 |
Drives: 21 ZL1 Join Date: Feb 2022
ZL1 a10 - why is it hard to get into the 10s vs 10speed Mustang GT??
Im super confused here. It seems like a stock a10 ZL1 really struggles to get through that 10 second mark stock even on a drag radial. When you compare power to weight to say a 2018+ 10speed mustang GT, those cars are very similar but with 200 less HP. And they are easily bumping into the 10s with a DR, E85 and some headers. Still well under the HP level of the ZL1, but effortlessly going deep 10s NA.
What is the difference? Those Mustangs are very close in weight. I really am struggling with justifying spending money on my ZL1 when I can take my big equity out on trade and get a loaded 10 speed GT with a $8k procharger and dip into the 9's. 10s are a joke to boosted gen 3 coyotes. Anyone care to shine some light on this? And furthermore what are we doing to get into the 10s? So far I have a setup of 17" DRs and a dry rotofab/no tune and best I have done with zero traction problems just stabbing it from idle is 11.4@124. That was in like 3000ft DA in the florida heat a few weeks ago. Am I going to be able to run 10.9 or something close once the DA drops and its in the 70s? This is very frustrating. |
05-29-2022, 07:10 AM | #2 |
As I’ve said previously here, met with total disbelief and BS flags, well sorted bolt on LT1/SS and GTs will out run a stock ZL1.
ZL1s really need a ECM and trans tune to be unleashed. Watch Jorge loves speed on YouTube to see how his car did stock vs tuned
05-29-2022, 07:18 AM | #3 |
I agree, unlock the trans, tune them both and you'll be in the 10s and might as well do a flex fuel sensor and run a small amount of E85. I think you can do it without the headers also.
05-29-2022, 07:35 AM | #4 |
I watched some of one of his Videos and that's impressive running 10.47 with just trans tune, E and CAI, plus the drag pack. I can tell my A10 doesn't perform anything like my A8 in the C7 and my old Camaro.
05-29-2022, 10:16 AM | #5 |
Trans tune.. The throttle will not open all the way through most of the rpm range(<5500rpm) for the first 3 gears until it's tuned.
2016 NFG 1SS A8
05-29-2022, 11:02 AM | #6 |
I have a 21 ZL1 so that means I have to buy the HPT unlocked T87a TCM correct? And have that installed? I also have to get a wideband installed for the tune itself. What a pain in the ass. Why no WB installed from the factory. Both the FORDs and Dodges have them now...
05-29-2022, 11:52 AM | #7 |
Mine has an unlocked T87a, but the tuning is not simple.
WB costs you $200-250. Then weld-in a single bung. Not sure these will result in 10s though
'20 ZL1 1LE A10,
05-30-2022, 07:42 AM | #8 |
Drives: 2008 Pontiac G8 GT, Shelby GT500 Join Date: Mar 2011
Why won’t the throttle open up all the way for the first 3 gears? Trying to preserve things or trying to keep traction manageable? Curious what their reason was.
Either way, I’d be interested in simply disabling that and touching nothing else. Is that’s all that is needed for 10s? |
05-30-2022, 07:57 AM | #9 |
Mine is tuned and shows 92% at wot
'20 ZL1 1LE A10,
OEM short block, LME heads/valve train, E2650. 100+ octanes, no eth, no meth, no N2O. 2/23 - 1031/1004 wheel. 4/23 - 1.41/9.61/145 at DA 7000 ft. (only made five passes). 2/24 - LME 390, E2650, FBO, 100 oct.; 1116hp/ 1063tq; 109 oct. dyno next. Last edited by JSH; 05-30-2022 at 07:48 PM. |
05-30-2022, 07:58 AM | #10 | |
'20 ZL1 1LE A10,
05-30-2022, 08:00 AM | #11 |
05-30-2022, 09:01 AM | #12 | |
If I Don’t touch the maf curve or enrichment tables, in my mind, wouldn’t need the wideband
05-30-2022, 09:01 AM | #13 | |
05-30-2022, 09:08 AM | #14 | |
Yes trans tune and tire should break into 10's in decent air. attatched below is after the trans tune. look at the TPS(%) difference.
2016 NFG 1SS A8
Options-2SS Leather/NPP Perf. mods-Whipple 2.9/Fuel System/Flex Fuel/103mm TB/Rotofab Big Gulp/Cat Deletes/Corsa NPP Per. times- 10.5 @ 137 w/ 1.8 60ft Full weight on 20's 1200DA Last edited by KingLT1; 05-30-2022 at 09:32 AM. |
