02-09-2021, 05:42 PM | #1 |
Drives: ZHP, Alfa 4C, RAM, X5, 17SS1LE-sold Join Date: May 2017
A10 SS 1LE Driving Impressions?
Anyone out there driven the A10 1LE extensively? Can you compare to the 6MT? Can you compare to others, ie 718 gts PDK, m3/4 DCT, other ZF A8 competitors?
02-09-2021, 06:28 PM | #2 |
雪の玉
Drives: '22 Z71 RST Silverado Join Date: Feb 2011
02-09-2021, 06:50 PM | #3 |
I was on track with one. It seemed as fast as the 6 speed lap time wise. It did get towed away one day, don't know why.
02-09-2021, 06:50 PM | #4 |
Good catch! Corrected to extensively
02-09-2021, 07:03 PM | #5 |
雪の玉
Thought that's what you meant but wasn't sure.
02-09-2021, 09:20 PM | #6 |
Drives: 18 Ford Raptor, 21 2SS 1LE M6 Join Date: Dec 2020
Shift the car into reverse while driving on the freeway can be expensive in an auto. I heard from dealers here in CA that they order a lot of autos as they shift faster and people prefer it on the track. Not sure since I had to order mine out of state for the manual. The a10 in my raptor in sport mode holds to redline, but upon decel it seems to hunt for gears. Sometimes it will slam from 4th or 6th down to first when coming to an abrupt stop. Hope it holds together, but glad I got the 8 yr. warranty.
02-10-2021, 07:39 AM | #7 |
Drives: 2018 Camaro SS1 1LE Join Date: Feb 2017
I went from a 2016 SS A8 (not the A10 you asked about) to a 2018 SS 1LE M6, and I much prefer the manual. Yeah, I know the automatics are supposed to be a tenth quicker through the quarter mile. Perhaps if I did a lot of quarter mile runs that would mean more to me, but since I'm using it as a DD, the M6 is just much more fun.
One thing I didn't like about the A8 was the number of gears. There are too many of them. I found myself searching around with those stupid paddles trying to do multiple downshifts, having to look to see what gear I was in. From my perspective moving to a 10 speed would make that even worse. With the M6. I have four solid gears to work with and two overdrive gears for cruising. I know the shift points well and even if I didn't have the HUD, I would still always be able to tell what gear I'm in. |
02-10-2021, 08:08 AM | #8 | |
Drives: 2022 SS 1LE Join Date: Dec 2020
Alpha Platform Aficionado
2022 Camaro SS 1LE | Rapid Blue | Manual Cadillac ATS 3.6 RWD | Daily Driver Previous: Challenger Scat Pack Widebody |
02-10-2021, 12:14 PM | #9 |
Drives: 2021 Camaro SS 1LE Join Date: May 2009
I love mine. At first it was very hard to adjust to it from driving a manual for so long, but I can tell you the shifting is spot on and holds the shifts as it should for maximum performance depending on the mode (Sport, Track) I personally really like it.
2021 Camaro 1SS 1LE - Red Hot
2015 Camaro Z/28 - Red Hot 2001 Mecham Trans Am #3 - 7.0L LS1 |
02-10-2021, 08:35 PM | #10 |
Drives: 2023 ZLE Join Date: Jun 2009
I had a 16 2SS with an A8 that I tracked quite a bit. That car made me never want another manual. I did get into a 19 1SS 1LE with the M6, which i also track regularly, and have to say it’s really good. If I were to order a new one, I might go with the A10 in the 1LE. I could see the gearing in the A10 help the car out of corners. It’s the only issue with the 1LE manual, sometimes it doesn’t pull hard enough out of a 3rd gear corner. That’s where the ZL1 and S/C really shine. I feel like the A10 might be a little better in that regard but it would be close. I’d certainly try one.
02-11-2021, 08:06 AM | #11 |
Thank you. Will PM for more info
02-11-2021, 11:40 AM | #12 | |
Drives: women crazy Join Date: Aug 2020
‘19 1SS A10, Borla S-type Non-NPP-SOLD
02-11-2021, 12:31 PM | #13 |
I believe my impression with manually shifting an A8, ie that it was too hard to find the gear I wanted, would be equally if not more applicable to an A10. If it bothers you that I posted that, why not just skip it rather than get snide?
02-11-2021, 02:33 PM | #14 |
Drives: 2SS 1LE Join Date: Oct 2011
I don't find that number of gears directly affects this. I've driven A8 cars that hunted and A8 cars that were smooth perfection.
2018 2SS 1LE 2023 Colorado ZR2 2022 Stinger GT-line AWD |
Thread Tools | |
