Old 04-23-2017, 09:04 PM   #15
RUQWIKR
RUQWIKR's Avatar
Drives: 1LEs
Originally Posted by seanblurr View Post
Install wasn't very difficult at all, it even comes with a clear plastic template you tape onto the blade spoiler that shows where to drill the holes. I'd say the largest issue for me was not having a metric rivnut tool, so I had to make my own tool using a bolt and nut. I noticed that my right side bows out a bit, so it seems that despite the template one of my holes was just slightly off. Not a huge issue, hardly noticeable. Install took less than an hour.
For others, check your local friendly Chevy dealer. They usually have the 6mm and 8mm riv nut tools for various GM Accessories like various mudguards, etc. They may let you borrow it, or you can make one quickly, too.
RUQWIKR is offline   Reply With Quote
Old 04-24-2017, 09:49 AM   #16
WILWAXU
WILWAXU's Avatar
Drives: 2019 Crush ZL1 1LE
Looks great! Thanks for sharing.
John Brown
Instagram @wilwaxu
Facebook @wilwaxu
WILWAXU is offline   Reply With Quote
Old 04-24-2017, 09:57 AM   #17
keon718nyc
Looks awesome and thanks for sharing, Your definitely the first to pimp out the GM Wickerbill!
Old 04-24-2017, 10:45 AM   #18
aka Reckless
aka Reckless's Avatar
Drives: 2016 2SS Camaro
1 - Does it cover the SS wing holes that you 1LE guys don't have to worry about?
2 - How much?
aka Reckless is offline   Reply With Quote
Old 04-24-2017, 10:48 AM   #19
keon718nyc
2 - How much?
The SS holes will not all be covered and you would either need to swap deck lids out or weld and repaint like i did to my SS deck lid to install the GM Blade Spoiler....
Old 05-01-2017, 10:07 AM   #20
seanblurr
seanblurr's Avatar
Drives: ZL1 1LE
seanblurr is offline   Reply With Quote
Old 05-01-2017, 11:23 AM   #21
MTS2020
MTS2020's Avatar
Drives: 2017 HBM SS 1LE
Seanblurr.....that looks bada$$!
Off topic, where did you get that license plate frame?
2017 SS 1LE Hyper Blue Metallic
2016 Yukon SLT White Frost Tricoat
2012 Maxima SV Sport Winter Frost Pearl
MTS2020 is offline   Reply With Quote
Old 05-01-2017, 11:40 AM   #22
MTS2020
MTS2020's Avatar
Nevermind.....found it on Phastek website.
Old 05-01-2017, 11:59 AM   #23
FNxR3DNECK
FNxR3DNECK's Avatar
Drives: 2017 SS 1LE
Man I wanted to get this but I would have to take it off when I run A-Street for Auto Cross since it would technically be an aero mod.... Oh well
IG: @NC_M1SS1LE
Old 05-01-2017, 01:09 PM   #24
mjk3888
"M1SS1LE"
mjk3888's Avatar
Drives: 2017 SS 1LE
Are you sure about that? Ask John. It might be okay since its and OEM available part. I would think if a car can be ordered with one then it should be okay.
Old 05-01-2017, 01:37 PM   #25
Ryephile
Hot Dog
Ryephile's Avatar
Drives: '17 1SS 1LE
Yes, your car looks amazing.
Old 05-01-2017, 01:45 PM   #26
seanblurr
seanblurr's Avatar
Drives: ZL1 1LE
This will very likely have NO effect at autocross speeds, so I don't see why you couldn't run it if you wanted it simply for looks.
I got the plate frame off eBay, though it may be the one that was added to Phastek.
Old 05-01-2017, 01:57 PM   #27
FNxR3DNECK
FNxR3DNECK's Avatar
Drives: 2017 SS 1LE
That's what john told me, same goes for the OEM cold air intake (if it ever even comes out) even though it's OEM part it's still not legal.
IG: @NC_M1SS1LE
Old 05-01-2017, 02:00 PM   #28
FNxR3DNECK
FNxR3DNECK's Avatar
Drives: 2017 SS 1LE
You are most likely 100% correct, I could run it but based on what I was told if I started winning and one person bitched about my "added aero" I would have to take it off.
IG: @NC_M1SS1LE
