09-25-2018, 07:58 PM | #1 |
Drives: 2016 2SS Convertible Join Date: May 2012
GM Patents Clutch By Wire
A new patent from GM could mean your next clutch pedal is a digital one.
https://www.gminsidenews.com/article...ual-trans-fun/ |
09-26-2018, 05:31 PM | #2 |
Tri-County Camaro SWFL
That's pretty insane
09-26-2018, 05:52 PM | #3 |
Drives: 2011 2SS/RS M6 Join Date: Oct 2015
Ford has a transmission in it's Focus(probably others too) that has a clutch disk, and is shifted by actuators. I have seen the guys across the shop changing the clutch and actuators quite regularly. Ford treats it like an automatic in that you select drive just like an automatic and it does the rest. An automatic clutch with a manual shift pattern and lever would be a lot more fun if the kinks can be worked out.
09-27-2018, 12:00 PM | #4 |
Drives: 1999 Camaro SS M6 - SBE LS1 Join Date: Jun 2018
The original Ferrari F1 (F1 meaning 575 Maranello, 360 Modena, etc) transmissions were this style - electric/hydraulic clutch setup with paddle shifters or full automatic mode.
1999 Camaro SS 6M - SBE LS1
1963 Corvette GrandSport - ZZ502 4M 2017 Denali 1500 6.2 2017 Yukon Denali 6.2 |
Thread Tools | |
