Old 06-22-2016, 08:44 PM   #1
Techn9cian805
The BEAST
Techn9cian805's Avatar
Drives: '16 2SS, '89 Wife
Tickincg/clicking sound when turning
Just within in the last few days i noticed a clicking/ticking sound coming from what sounds like the rear half of the car, and it alternates from the left and right depending on what direction im turning towards, and it seems to be getting louder. The ticking/clicking happens when the steering wheel is turned more than 90 degrees, and sounds like what a playing card would sound like when hitting a bicycle wheel spoke. Anyone know what it could be? Due to work, i cant take the car to the dealership till next week. Any help, advice, and knowledge is welcome
Scarlet: 3/3/16: 2SS Red Hot, M6,
Instagram: @luis_what_it_is
Techn9cian805 is offline   Reply With Quote
Old 06-22-2016, 09:15 PM   #2
stratt
Drives: Waiting on my 2016 Camaro 2SS
Search for rear differential service bulletin on this site. Take it to dealership and they will put the right fluid in the rear diff.
stratt is offline   Reply With Quote
Old 06-22-2016, 10:06 PM   #3
Techn9cian805
The BEAST
Idk if thats it. Those with the rear diff issue describe theirs like a groan or growl. Mine is more like a ticking sound, just imagine yourself walking by a picket fence and hitting every post with a stick as you walk. It sounds like that. And its most audible at speeds above 15mph
Old 06-23-2016, 10:52 AM   #4
Ejplain2
Drives: Waiting on 2016 Camaro SS
Bring your Camaro into the dealership ASAP I had the same problem the rear axle is causing that ticking noise on Sunday I heard the ticking and I was driving down a street that I drive on daily and went to turn on the left side where I heard the ticking and the axle came completely disconnected so I had to call roadside assistance to get towed to the dealership where I work at turns out the bolts for the rear axle was broken. I only hear the ticking sounds a low speed around 20 mph or less
2016 1SS Order#TBWC91 Mosaic Black, MN6,NPP, 56R
1100: 12/03/2015
2000: 12/07/2015
2500: 12/08/2015
3000: 12/09/2015 - TPW 01/11/2016
3100: 12/17/2015 - TPW 01/18/2016
3300: 12/22/2015 - TPW 01/11/2016
3400: 12/23/2015
3800: 01/19/2016 - Vin G0140892
4000: 01/19/2016
4150: 01/19/2016
4B00: 01/19/2016
Ejplain2 is offline   Reply With Quote
Old 06-23-2016, 01:26 PM   #5
Chevrolet Customer Svc
Chevrolet Customer Svc's Avatar
Drives: GM Vehicles
Hello Techn9cian805,
I’m sorry to learn your Camaro has developed a ticking concern and recognize how displeasing this could be while driving. Since we are not certified technicians, we’re unable to speculate the root of this concern. However, we’d be glad to set up an appointment at your preferred dealership at a time that works best for you.
Please send us a private message with your current mileage, full contact information, and preferred dealership if this is of interest.
Steph B
Chevrolet Customer Care
Chevrolet Customer Svc is offline   Reply With Quote
Old 09-07-2016, 04:35 PM   #6
G.Edwan
Drives: 2SS Sliver BS MRC NPP A8
Hi. I have the same sound, is it normal ? And what's the cause
G.Edwan is offline   Reply With Quote
Old 09-07-2016, 06:31 PM   #7
JRS
JRS's Avatar
Drives: 16 camaro M6/ 18 ZL1 camaro A10
The clicking noise you are describing was posted in an earlier post by Razzaa which I explained what I thought it was here was my reply.
http://www.camaro6.com/forums/showthread.php?t=463175
I have heard a noises from mine when cornering hard, I don't know if it is the clicking sound you heard but on my Camaro it turned out to be the wheels needed to be re torqued to 140 ft lbs. The car original where only torqued to 120 and they add slip of paper in with the owner manual stating they needed to be torqued to 140. The best I can describe the noise is if you ran the car hard then parked it and you heard that cracking noise from the rims which is from the metal hub heating up the aluminum wheels and the wheels cooling faster than the metal causing them to slide on one another making a cracking noise. I hope this helps!
JRS is offline   Reply With Quote
Old 09-11-2016, 02:30 AM   #8
T_B
T_B's Avatar
Drives: 2016 2SS
could it still be rear differential fluid if i hear it only during left turns with the wheel locked?
T_B is offline   Reply With Quote
Old 09-15-2016, 06:10 AM   #9
G.Edwan
HI,
i had the same issue and its fixed, check below service-bulletin, its has the Camaro listed.
http://www.corvetteactioncenter.com/...2016-1301.html
Old 03-30-2018, 05:17 PM   #10
zackf80m
Drives: Camaro ZL1
Ever fix this issue?
zackf80m is offline   Reply With Quote
Old 09-21-2018, 07:02 PM   #11
custommx3
custommx3's Avatar
Drives: 2017 2SS, 2023 3LT RS, 2011 2LT RS
Had the issue! This fixed mine! Thank you. It saved me a trip to the dealership.
custommx3 is offline   Reply With Quote
