06-18-2015, 10:11 AM | #1 |
Drives: 2014 1le Join Date: Dec 2014
Brake fluid reservoir leaking from cap
I'm not sure where best to post this, but maybe the 1le forum will work as people that buy 1les probably like taking corners.
My brake fluid reservoir always has drips running down the side of it. I clean if off, and it happens again. At first I thought I just had it overfilled (even thought it was below the full line), but it is still doing it even thought the fluid level is about half way from min to max. I know the cap is supposed to breath, but it still seems a bit excessive and I worry about the paint below corroding. Anyone experience this or know of a work around?
06-18-2015, 10:32 AM | #2 |
The BBOMG fill-in husband
Drives: 2015 2SS/RS 1LE AKA V1LE Join Date: Aug 2010
Mine did that too, but after a few times of wiping and taking the cap off and on it has stopped....for now, lol
UPSTATE C5 MEMBER
06-18-2015, 10:37 AM | #3 |
Drives: 1LE Join Date: Jul 2011
I had the EXACT SAME problem with my brand new 1LE.
The solution for me was as follows: -Document the problem with dealership, let them change the cap. -Take photos of the still leaking reservoir + send email to dealership asking for reservoir replacement. -While waiting for the parts & appointment, install a separate reservoir for the clutch fluid.(I used the GTO reservoir) -Have them install the brand new reservoir that comes capped from the factory(and is MUCH tighter) I believe the combination of clutch press/depress + hard cornering causes the fluid to leak from their crappy stock reservoir. It was not leaking anymore just by installing the GTO mod, but I still had them install a new one because it is much nicer(and secure?) to have it capped from the factory. Whatever you do, do it fast, or you will end up with fluid dripping out of the reservoir and eating out the paint on your brake booster. |
06-18-2015, 12:39 PM | #4 |
Drives: 2015 1SS / RS NPP Join Date: Apr 2015
This thread post #2 has a relevant TSB. It's something to keep an eye out for.
There have been several threads on various sub-forums regarding this issue, the paint damage that can result, etc. |
06-18-2015, 01:48 PM | #5 |
Drives: 2013 2SS/RS/1LE Join Date: Apr 2010
Kit from JDP: http://www.jdpmotorsports.com/jdp-mo...s-zl1-jdpc1002
06-18-2015, 02:35 PM | #6 |
Thanks for the responses. I am going to try shimming the stock cap before I deal with the dealership (I really hate going to the dealership). I don't think the reservoir itself is the problem as my motive bleeder hooks up and maintains pressure.
06-18-2015, 02:47 PM | #7 |
06-18-2015, 03:03 PM | #8 |
ultracrepidarianism
Drives: '14 1SS/RS/1LE/NPP '18 Accord Sport Join Date: Mar 2014
This worked for me.
06-18-2015, 06:38 PM | #9 |
Drives: 1LE Join Date: Feb 2013
Based on the threads out there on this subject, I bought 42072 as a precaution. Definitely fits tighter than the stock gasket.
06-18-2015, 07:00 PM | #10 |
06-18-2015, 08:15 PM | #11 |
Drives: 2017 Jaguar F Type R Tuned 498awhp Join Date: Apr 2013
This is the solution to the problem. Myself and many forum members have used this to fix the leaking cap. You would think GM would have made a design improvement since 2010 to address this issue
JRE cammed w.full bolt ons 444rwhp/422rwtq SOLD
2017 Jaguar F Type R ''Life moves pretty fast. If you don't stop and look around once in a while, you could miss it.'' - F. Bueller |
06-18-2015, 08:48 PM | #12 |
I sill believe the clutch fluid will get much more dirty than brake fluid.(if driven hard)
contamination might occur, that's why I went with the separate reservoir option. |
06-18-2015, 09:04 PM | #13 |
Drives: 2022 1SS 1LE A10 BCD WCT+PDR Join Date: Mar 2008
There is no issue with the reservoir leaking. The cap has a slit, any build up of pressure from heat, pushes some fluid out between the rubber diaphragm and the cap where it leaks down onto the reservoir. Pressure equalizes, slit seals up, no moist air enters the reservoir.
Go to my build thread for more info, starting at post #29 and then to post #57 http://www.camaro5.com/forums/showthread.php?t=395103 And yes, I have the Dorman 42072 and it has the slit
06-18-2015, 09:07 PM | #14 | |
-Why does GM put a slit in the cap diaphragm?
