Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Technical Camaro Topics > Camaro Issues / Problems | Warranty Discussions | TSB and Recalls
Old 04-04-2017, 02:40 PM   #1
Alrogi
Drives: Camaro RS
Overheat
Hey folks, I'm having trouble for over a year now. My car gets overheating like 250 degree and over when idle that makes the fan start working hard but the temperature keeps rising. This happens when I drive the car in town for awhile and set it to idle, but when I drive again, temperature reduces. I had it checked into many shops, but the answers are the same which is everything is good since the car doesn't overheat there. Anybody had this problem before? Please help
Alrogi is offline   Reply With Quote
Old 04-04-2017, 10:19 PM   #2
tlavoie87
Built Not Bought
tlavoie87's Avatar
Drives: 2010 Twin Turbo LFX
v6 or 8
2010 Twin Turbo LFX
In Memory of my DAD Gone but never Forgotten 2014
"Built Not Bought!'
Sponsors:
OverKill Motorsports
tlavoie87 is offline   Reply With Quote
Old 04-10-2017, 12:04 AM   #3
Alrogi
Drives: Camaro RS
It's a v6
Old 04-10-2017, 06:48 AM   #4
Abelardoo_12
Abelardoo_12's Avatar
Drives: 2011 camaro ss convertible
Did you check the coolant level on the radiator and the surge tank ? I had the same problem and I would only checked the radiator for the coolant level, turned out I didnt have any coolant on the surge tank, I refilled it and everything was good again. If you haven't checked there already you might want to look there and check if there's coolant.
Abelardoo_12 is offline   Reply With Quote
Old 04-12-2017, 06:15 PM   #5
hussain112ali
hussain112ali's Avatar
Drives: Camaro V6 2LT RS 2012
Send a message via Skype™ to hussain112ali
Thumbs up
If you checked all that and still facing the same issue ... consider replacing the coolant sensor
hussain112ali is offline   Reply With Quote
engine, mechanics, overheating, radiator
