View Poll Results: What would you do with your 1LE?
Leave it alone 16 22.86%
Build all motor 36 51.43%
Build for Procharger 14 20.00%
Other, please explain 4 5.71%
Voters: 70. You may not vote on this poll
Old 02-08-2019, 05:25 PM   #29
sal11585
Drives: 2017 Camaro SS 2ss Nightfall Gray
A lt4 swap sounds like a bad idea to me, you could def sell your current car and upgrade to a zl1 with the cost of the swap
ACS front spoiler, rear spoiler, side skirts and rock guards (gloss black). Real carbon fiber dash insert, real carbon fiber gear bezel, GM dark tail lights, Gm black badges(Emblems and ss)
Powder-coated gloss black factory 5 spoke split wheels
Roto fab Biggulp CAI
Full paint correction with cquartz finest ceramic coating
Whipple 2.9
ARH Long tube headers with High flow cats
1le sway bars F&R
BMR Upper and lower trailing arms
Hurst short throw shifter
sal11585 is offline   Reply With Quote
Old 02-09-2019, 05:47 PM   #30
SpazmXylam
Because Racecar!
SpazmXylam's Avatar
Drives: 17 SS 1LE
Agreed. An SS to ZL1 swap would be more reasonable imo.
OP sounds like the long term power goals are going to keep rising. Stepping into a ZL1 now and using that as the foundation will likely be much cheaper for big power since it was designed from the beginning as a forced induction application as opposed to building up an LT1 in several stages.
Though, my vote and plans for my car is for N/A all motor. Likely not until after I am on the hook for an engine instead of the warranty. Not that I am expecting such an issue but track duty does take its toll.
SpazmXylam is offline   Reply With Quote
Old 02-09-2019, 06:58 PM   #31
Boost Creep
Boost Creep's Avatar
Drives: '18 1SS 1LE
Do bolt ons first. Headers etc.
When more power is desired, throw in a cam.
More power? Heads.
Then if that isn't enough, go for FI.
'18 1SS 1LE Black, PDR
Old 02-09-2019, 07:20 PM   #32
grampa_ss
grampa_ss's Avatar
WTH...this thread is almost 2 years old.
Old 02-11-2019, 01:06 PM   #33
GTSLOW
Daily Driven 1LE
GTSLOW's Avatar
Drives: 2018 1SS 1LE
There's guys making 530-550 at the wheels with H/C/I/E85 packages. I can't see why one would spend the money on a supercharger when you can have that without. Plus the last dynograph I saw lost no power at any range. Very impressive!
2018 1SS 1LE
GTSLOW is offline   Reply With Quote
