02-25-2021, 09:26 PM | #1 |
Drives: 2019 2SS Camaro Join Date: Apr 2012
LT2 intake primary cat removed v4 Big Knock Performance
Just a heads up that if you have the lt2 intake with primay cats removed when the car coast a little in v4 then step on the gas slightly normal driveing gets huge knock like 8 deg retard. All stock car and tune. Turn off v4 problem completly goes away.
Removed cats not a lot of difference in feel and 0-60 and 100 might have done just a little better. There was no loss of power in low end. It felt to my butt dyno improved every where. I then added the lt2 intake. Picked up .2 in 0 to 60 and 1.2 seconds to 100. Impressive!! Air denesty went from -500 before parts test to 600 + wth the mods so. This is a bone stock car with stock tune. afr went slightly richer from the normal 12.5 to about 12.3. It does have the nitto 2 305 35s. Stock 275s are well junk. Then in normal driveing was getting the crazy big knock when doing the v4 stuff. Also makes a different noise when it goes into v4. Like a baffeling sound. the v4 valves closeing no doubt cause it would go very quite even when I use the foerenz thing to open the valves. With cats you do not hear that sound. Turned v4 off and all knock completly went away. I would say NOT fake. So just a heads up from my experience. After i put on the lt2 when I hit it felt much stronger. Edit I mis spoke on the times 0-60 stock 4.1 to 100 9.7. Thats with the nitto 2 stock tires are about 4.5 lots of spin. This is all useing launch control default settings for consistancey. Gutted primary cats 4 and 9.6 that could be just run difference. Their was no loss in bottom end. LT2 3.8 and 8.8 still impressive and noticeable stronger. Then stock stage 2 procharger was 3.6 and 7.6 thats the 1.2 second. Opps. Showing 6.5 pds at stock shift point. Also with those mods my injecter was going near 7 micro second or what ever and rail pressure was dropping to 1800 psi. So defentaly more air flow and out of fuel with the base procharger. I will get the meth working before I run it any more and get the duty cycle down. Last edited by Kerry; 02-26-2021 at 03:24 AM. |
02-25-2021, 10:30 PM | #2 |
Good feedback. Did you have stock or ported LT1 before doing the swap?
02-26-2021, 03:13 AM | #3 |
Stock
02-26-2021, 03:31 AM | #4 |
Question with primary cats removed it is some louder. Not crazy but some. What would happen if I removed the secondary. Would power go up? How much Louder? 10% 30?
