02-24-2021, 09:15 AM | #1 |
Drives: 2016 Camaro SS in Red Hot Join Date: Apr 2016
Engine Fan Stays On
My engine fan ran nonstop during my entire commute this morning, then continued to run for about five minutes after I shut the car off. Gave it a few minutes and then fired up the car again. Same thing--fan ran for five minutes after turning off the car. Engine temp is low, so it's not overheating. Coolant level looks good. Thoughts?
02-24-2021, 09:21 AM | #2 |
Drives: 23 ZL1 6speed Join Date: Aug 2020
Have you tried disconnecting the battery for a few minutes? Otherwise my first thought was low coolant - which you said is OK. Second guess is the thermostat is acting up.
02-24-2021, 09:28 AM | #3 |
Drives: '21 Wild Cherry ZL1 Join Date: Aug 2018
02-24-2021, 09:53 AM | #4 |
No, I didn't try disconnecting the battery. I'm at work with no access to tools. I can see under the hood that the coolant overflow bottle is about half full, which I take to be a good sign.
02-24-2021, 09:58 AM | #5 |
Drives: 2016 2SS Convertible Join Date: Dec 2019
Disconnecting the battery probably won't do anything. There are a few threads here that discuss this issue exactly. My wife's previous '11 CTS did this at one time too (traded it in for a gently used '16 CTS instead of paying for the repair...they gave us full+ trade-in anyway). It's likely the 'stat or the temp sensor.
Hyper Blue/Ash Gray A8 Magnetic Ride Control Dual Mode Exhaust 2019+ version Split Spoke Silver Wheels Navigation Silver Rally Stripes |
02-24-2021, 10:22 AM | #6 | |
02-24-2021, 11:28 AM | #7 | |
Go Arizona Cardinals
Drives: 2006 GMC Duramax 2500 HD, 2016 2SS Join Date: Sep 2015
2015 Nissan Murano SL with Tech Package
2006 Lifted GMC Duramax 2500 HD. Lot's of custom parts! 2016 2SS Garnet Red 2SS,6 Speed, NPP, MRC, Adrenaline Red interior, Black Rally Stripes, NAV, Sunroof, Corvette Z51 Black Wheels, Black Front Fascia, aFe / PFADT Suspension Lowering Springs, Black High Rise Rear Spoiler. High flow headers, E85, Roto-Fab Cold Air, MSD Atomic AirForce Intake. aFe / PFADT Front & Rear Sway Bar. Pushing 520 to the Rear Wheels |
02-24-2021, 02:47 PM | #8 |
Drives: 2016 Camaro 2SS Convertible Join Date: Sep 2016
I've had this happen 2-3 times in the last few months. Every time it has happened, my coolant level was fine and the engine was not running hot. What made each incident even more puzzling is outside temps were low (40s-50s).
1996 Camaro Z28 with T-Tops (Sold 10.22.16) 1986 Camaro IROC-Z with T-Tops (Sold) 1961 Volkswagen Beetle with Sliding Ragtop Sunroof (2009-Present) 1964 Volkswagen Beetle with aftermarket Sliding Ragtop Sunroof (Sold) Follow me on Instagram - @gen6_2ss_vert |
02-24-2021, 02:50 PM | #9 |
Same with me. I know I'm in Arizona, but it's only February so it's still cool. Outside temp when I arrived at work was in the 50s. Maybe after a few cycles on and off the problem will go away. In the meantime, I made an appointment to take the car to the shop on Monday. If it fixes itself by then, I'll skip the appointment.
02-24-2021, 03:02 PM | #10 |
Drives: Chevrolet Camaro 2SS Join Date: Nov 2019
I had this happen when I forgot to plug the MAF back in after installing my CAI. Don't know if you've installed anything new lately?
02-24-2021, 03:13 PM | #11 |
Resident Land Surveyor
Drives: 2016 Camaro 1SS - Summit White M6 Join Date: Aug 2016
I can promise you it is the thermostat sticking open, causing your car to go into safe mode because it actually reads too low of a temp consistently. Temp gauge drops to 0, fans kick on to 100%, rev match won't work (if you have manual). I went through this multiple times over the course of a year, disconnected and reset, replaced the temp gauge, until I was finally told it was the thermostat causing all of my issues. I have seen this exact problem pop up for many over a few different forums/facebook pages, so I'm guessing our thermostats aren't so great. 10 minute install, cheap and easy fix. Thermostat is right on the top of the engine. If you're under warranty and don't feel comfortable doing it yourself, point the dealer in that direction.
2016 Summit 1SS 49th Anniversary Commemorative Limited Plutonium Edition - M6, Solo Axleback & !RearCats, Ultra-Rare Cloth Seats, Forgestar CF5V 19x10-285/35 19x11-325/30
2001 NBM Trans Am WS6, Wifey's Grocery Getter - Torquer V2 cam, Racetronix Fuel Pump, Yank 3000 Stall, Transgo 1-2 kit, TSP LTs, Magnaflow, Strano Springs/Koni STR.T shocks, 17x9.5/17x11 TTIIs, Ed Wright tuned |
02-24-2021, 03:15 PM | #12 |
Drives: Garnet 2 LT, black wheels, A8, V6 Join Date: Apr 2016
That happened to me. It was the thermostat and temp sensor. It was a quick fix at the dealer.
02-24-2021, 04:54 PM | #13 | |
Drives: 2016 Camaro 1LT Join Date: Jan 2016
I wish it was a simple install for the lgx. They put that stupid thing right in the valley underneath the intake manifold underneath a hard oil/trans return line below the hose level of the radiator. So you have to take the intake manifold fully off, then fabricate your own wrench most likely to get at the thermostat bolts and bend or remove the return line to take it off, all while you're dumping coolant (or having to partially drain it prior to working). Pretty sure the designer of that piece of crap has family in the dealership business. It's unnecessarily difficult for something that seems fairly failure prone after 5 years of age. |
02-24-2021, 06:41 PM | #14 |
Drives: 2021 Camaro LT1 Join Date: Sep 2020
Never heard mine come on.
