02-26-2021, 05:37 PM | #43 |
Drives: Make it a 6 speed in SS trim. Join Date: Feb 2021
Formatting ExFat won't even recognize and music on the drive. I've always used Fat32 and its hit or miss. I'm going to try NTFS.
02-27-2021, 09:44 PM | #44 | |
Drives: '17 2SS convertible'20 Yukon Denali Join Date: Nov 2011
I've used NTFS with spotty results. Part of the problem is that I was using a 64GB USB stick. Getting a 32GB stick.
Richard
2017 2SS SIM convertible, A8, NPP, MRC, 56R wheels, GM CAI, Diode Dynamics Side Markers Delivered: 08/15/2016 #TeamBeckyD |
02-27-2021, 10:29 PM | #45 |
Drives: 2016 Camaro SS M6 Join Date: Oct 2016
Most Android phones has a microSD card slot that can store up to 1TB In addition to the phone's storage. So you never run out of space taking pictures, videos or store music. I personally have 512GB card in mine and I just move phone to phone when I get a new one and everything is right where it should be. Don't have to rely on the cloud connection.
02-27-2021, 11:49 PM | #46 |
Just to mention another alternative, I installed a Silverado USB panel with an integrated card reader in place of the one we get in the center console, and it works perfectly. The infotainment screen even shows an SD icon when a card is inserted, so it's clearly designed to support the reader, we just didn't get the better version of the USB component.
735 rwhp | 665 rwtq Magnuson TVS 2300 80mm pulley | Kooks 1 7/8" LT headers | JRE smooth idle terminator cam | LT4 FS & injectors | TSP forged pistons & rods JMS PowerMAX | DSX flex fuel kit | Roto-Fab CAI | Soler 95mm LT5 TB | 1LE wheels | 1LE brakes | BMR rear cradle lockout | JRE custom tune 1100 - 1/30/18 | 2000 - 1/31/18 3000 - 2/06/18 TPW 2/26/18 3400 - 2/19/18 | 3800 - 2/26/18 4300 - 2/27/18 | 4B00 - 3/01/18 4200 - 3/05/18 | 4800 - 3/14/18 5000 - 3/16/18 | 6000 - 3/19/18 Last edited by arpad_m; 02-28-2021 at 12:11 AM. |
02-28-2021, 07:22 AM | #47 | |
Hot Camaro
02-28-2021, 08:35 AM | #48 |
Hmm, isn't the micro SD slot under the cover, typically stacked with the SIM card slot on 99% of phones? I guess you only mean those with an external slot.
02-28-2021, 09:05 AM | #49 | |
I think the reason they drop is because of cost cutting and more real estate for battery or other hardware. Or they're just trying to make you pay more for space like Apple. |
02-28-2021, 10:01 AM | #50 |
Drives: 2023 ZL1 Vert M6 "Sharky" Join Date: Mar 2020
real estate for the 893 cameras
2023 Camaro ZL1 Vert TR-6060 Sharkskin "Sharky"
Firecracker Red Wrangler Willys, 3.6L eTorque, 850RE 8 speed automatic, 25W Willys package, Technology Group, Convenience Group (aka $600 garage door opener), Cold weather Group, Trailer Tow and HD electric group with AUX switches, 3 piece black freedom top. |
02-28-2021, 07:00 PM | #51 | |
Hot Camaro
If you look at the details for pretty much any of the 'flagship' phones, none have a slot for a MicroSD card any more. The only place you can insert anything is the SIM slot. Just like they no longer have headphone jacks, for basically the same supposed reason. Personally, I feel that they've pulled these items out to make room for more battery in the device without making the phone larger. |
02-28-2021, 11:12 PM | #52 | |
Somewhere in the Kalahari
Drives: 2021/18 (de-fresh) 3LT RS Join Date: Dec 2017
By the way, I have those same compartment inserts, but with the white accent line that glows in the dark. On the subject of USB flash drives, I was using a tiny 32mb Sandisk drive in my '16 1LT. Occasionally the drive was not recognized at startup in the '16, and I would have to unplug it and plug it back in to get it to work. After reading this thread I figured I'd try a different USB drive for my '21 3LT. Only a couple days in, but so far this one has been working for me: https:/www.amazon.com/dp/B077VXV323/ Both my old and new Sandisk drives were FAT32 formatted, by the way. The nice surprise that came out of setting up a new flash drive is that I discovered my '21 does not have the 5,000 mp3 file limit that the '16 1LT did. I'll have to update my playlists! |
03-01-2021, 12:43 PM | #53 | |
USB in the Camaro any year can be spotty Even my LT1 sometimes fails to recognize the USB and I have the latest update. My 2017 Accord is much better.
03-01-2021, 02:27 PM | #54 |
Thanks. The original idea came from another forum member (chris227), but I did post about the install in this thread.
That's cool Mine are striped in red to match the rest of the interior theme.
03-10-2021, 11:18 AM | #55 |
OK I reformatted it to NTFS...it worked fine for about 3 days then it was hit or miss but less so, plus this time at least it seemed always see the drive but this time just not see the music. I didn't pull it out to reset it, but the next day I played it and it works. So NTFS works just better but not 100% dependable. Anyone know a 100% fix.
03-10-2021, 11:20 AM | #56 | |
So its the cars USB drive and not the formatting of the stick? If so sounds like a warranty issue. |
