Old 01-31-2021, 01:19 PM   #1
Redwings1
Drives: 23 ZL1, 22 C8 Sold. 21 LT1 Sold
ZL-1 knock offs will they fit a lowered LT-1
Looking to buy a set of ZL-1 pops. 20x10 23mm back space with 285 30 20. and 20x11 43mm back space w/20 30 305. I have BMR-SP041 lowering springs 3/4" drop in front and 1" in the rear. Will it all fit? Do I need a lower drop since there not 35 series? Thanks Steve
Redwings1 is offline   Reply With Quote
Old 02-01-2021, 10:27 PM   #2
Redwings1
Nobody's put ZL-1 wheels on a LT-1 or SS? Please help.
Old 02-02-2021, 04:29 AM   #3
BrandanK
Drives: 2021 Camaro SS 1LE
The LT1 suspension is the same as the non mag ride SS, so any data you find for the SS is valid for the LT1.
I am adding 1LE wheels in the spring, along with the GM suspension kit. From what I have gathered, if you run the normal 285/305 30 series tires, you should be okay with most lowering spring combos. Where I have heard of issues is if you go with different wheel offsets or different tire sizes.
Brandan
BrandanK is offline   Reply With Quote
Old 02-02-2021, 11:46 AM   #4
Redwings1
cool thanks. 305/30-20 on the rear?
