Old 12-25-2020, 02:34 PM   #29
Daddy_OZL1
Drives: 2020 Chevy Camaro ZL1
Shouldn't be a problem and will look & ride a tiny bit better. See the comparison of the fronts below, rears are very similar.
Thanks brother
Merry Christmas
Daddy_OZL1 is offline   Reply With Quote
Old 01-21-2021, 10:46 AM   #30
TP2SS
TP2SS's Avatar
Drives: 2016 2SS Convertible
Arpad,
What is the website where you screenshot this comparison?
Thx
Hyper Blue/Ash Gray
A8
Magnetic Ride Control
Dual Mode Exhaust
2019+ version Split Spoke Silver Wheels
Navigation
Silver Rally Stripes
TP2SS is offline   Reply With Quote
Old 01-28-2021, 10:56 PM   #31
Redwings1
Drives: 23 ZL1, 22 C8 Sold. 21 LT1 Sold
SS wheels 9.5 on all corners.
Bought a LT-1 and haven't gotten it home yet. The dealer is suppose to put 9.5 on all 4 corners with stock tires. Then I'm going to put Michelin Pilot A/S 3's 285/35-20 on al four corners. They say it with work. What say you guys?
Redwings1 is offline   Reply With Quote
Old 01-28-2021, 11:11 PM   #32
Originally Posted by TP2SS View Post
Arpad,
Thx
https://www.wheel-size.com
(Sorry for the late response, I've only just seen your question )
Old 01-29-2021, 02:19 PM   #33
Msquared
Msquared's Avatar
Drives: Chevrolet SS 1LE
Rear SS wheels are 9.5" with 39mm offset. Fronts are 8.5 with 20mm offset. I think you're likely to need spacers if you try to run the rears on the front.
Matt Miller
2020 SS 1LE
Msquared is offline   Reply With Quote
Old 02-28-2021, 07:53 AM   #34
Crushin_LT1
Crushin_LT1's Avatar
Drives: 2021 LT1 6spd
Do you know what size spacer?
Current: 2021 LT1 Camaro, 6spd, Crush, Corsa NPP, GMPP CAI, Soler Performance Throttle controller
Previous: 1997 V6 Camaro, 5spd, Black
Crushin_LT1 is offline   Reply With Quote
Old 02-28-2021, 08:45 AM   #35
Msquared
Msquared's Avatar
No, I don't. You'd have to try fitting one to see if clears everything. What I can tell you is that SS rear has 1/2" more backspacing than a front 1LE wheel, and the front 1LE is pretty close to touching. So you're likely to need at least 1/4" and possibly up to 1/2". There's nothing inherently wrong with running plain spacers, but at those thicknesses you'd need to install longer wheel studs up front.
Matt Miller
2020 SS 1LE
