09-20-2020, 08:09 AM | #1 |
Drives: 2013 Camaro 2SS/RS Join Date: Aug 2020
14 MPG
By comparison to y'all I wonder since I have owned my car, al L99, the indicator shows average fuel at 14.0 mpg. I drive 50/50 stop and go and highway. Is the mileage low, high, or average for the 2013 2ss L99 at 100K miles?
09-20-2020, 08:24 AM | #2 |
Drives: 2010 Inferno Orange 2SS/RS Join Date: Apr 2010
I average 16mpg.
Do you reset the parameters often?
2010 Inferno Orange 2SS/RS M6 Black Leather, Sun Roof, OBX Headers, Borla touring axle back, Cold Air Inductions CAI , non synthetic fluids, BMR total bushing upgrade/1" lowering springs, DSE 32mm rear sway bar. GM fe4 shocks/struts/LCA's, AAM 3.91 diff, Vertini RFS1.8 20x9 +30. Conti ExtremeContact Sport 275/35/20. sjm autoprod ABL dash kit. Mike Norris tuned 413/419.
Avenging Orange: 43 years of not buying into the Hype........and damn proud of it!! https://youtu.be/9JD9it6SmB8 https://youtu.be/xmelTlEzI34 KICKING CANCERS ASS SINCE 2015!! |
09-20-2020, 08:29 AM | #3 |
Sporting Foole
Drives: 2010 Camaro SS Join Date: Sep 2019
100 mile commute daily for me, I don’t “tip toe” around but I also don’t launch at every stop.
I’m averaging 21mpg - LS3 & manual 6 sp. |
09-20-2020, 08:47 AM | #4 |
My average is 19.9 and I have a mix city/Hwy commute.
2013 Camaro SS/RS, Stainless Power long tube headers with HF's, Air Raid CAI, Solo Mach XL cat back, BC Racing coil overs, Elite Engineering catch can, Ferrada Forge 8 Wheels, Windows tinted at 20%, Tuned by Dyno Steve.
09-20-2020, 09:28 AM | #5 |
Drives: 2013 Camaro SS Join Date: Feb 2017
16.7 mostly in town some highway.
2013 Camaro SS
Kooks Headers Vararam DRX 1le Differential 3.91 Bo White throttle body Magnaflow Competition Exhaust 12.391 112 MPH 10/05/19 |
09-20-2020, 09:31 AM | #6 |
Drives: 2014 Camaro SS 1Le Join Date: Feb 2016
MPG LOL...
2014 SS 1LE Money Pit/ Forged 402
CAM 22X/24X, .619/.617, 113 LSA/ LS9 Heads FIC 1200cc/DSX Aux Pump//McLeod RXT Clutch 730whp: 630Trq |
09-20-2020, 10:08 AM | #7 |
Fast Cars and Old Guitars
Drives: 2015 2SS RS (L99, baby!) Join Date: Apr 2012
“I don’t want to belong to any club that would have me as a member.” - Groucho Marx
09-20-2020, 10:12 AM | #8 |
09-20-2020, 10:28 AM | #9 |
It don’t come easy.
When the mpg is in the DIC, press the center button in the end of the turn signal lever.
09-20-2020, 10:43 AM | #10 |
Drives: 2014 2SS/RS Join Date: Jan 2014
I reset mine when I fill up usually ('14 SS/RS L99), so I don't have a long-term number... However, if you do what's called "spirited" driving, I don't think that's all that low. I would guess that my average over the last 6 years is around 16 or so. I tend to baby mine too much I think, as I've only spun the back tires about 4 times! I know that's not normal, but I got most of that out of my system back in the 70's :-)
09-20-2020, 11:13 AM | #11 |
Is this a "stock" car? If so reset the parameters and keep an eye on it. I used to get around 16-18 stock. I have a big cam and a 4200 stall now on on average in town and highway driving, 50/50 I will get about 13-14 which isn't too bad for 475rwhp 4000lb car.lol
09-20-2020, 11:34 AM | #12 |
Drives: 2010 Camaro 2SSRS M6 Join Date: Jan 2019
More like GPM instead of MPG
ECS supercharger, custom ground cam, ported throttle body, long tube headers, aeromotive fuel pump, fic injectors, ATI super damper, Corsa Extreme exhaust, elite engineering catch can and many other things.
09-20-2020, 11:49 AM | #13 |
Drives: 2014 1SS/1LE Join Date: Nov 2015
I used to average about 16 mpg with basic bolt-ons before the current build. Now the DIC shows I'm making 25 but it's about half that in reality.
Sent from my Pixel XL using Tapatalk
830 WHP 700 WTQ, Whipple 2.9 @ 13lbs Boost, Flex Fuel Tune by Blevins Tuning, LSA SBE, 3.5 GripTec, ATI LS3 Damper, AFR 260cc Mongoose, ARP Studs, Yella Terra Ultralites, Johnson 2110R, BTR PDS Stage 3, Melling 10355, Improved Racing Baffle, ID1050X, DSX Triple Fuel Pump, RotoFab CAI, NW 103mm TB, Stainless Works 1-7/8" LTH to 3" Speed Eng w/ X-pipe to NPP, Powermaster 9509 XS, Detroit Speed Motor Mounts, MGW, Monster LT1-S, ZL1 Calipers, DBA Rotors & Pads, Bilstein B6 Struts & Shocks, BMR 1.25" Drop Springs & Adj Rear Bar, Pegasus Solid Bushings, Z/28 Wheels, other misc parts.
09-20-2020, 11:54 AM | #14 | |
I bought from a dealer. It is stock I suspect because the dyno was 350rwhp. I did find out how to reset by holding in the button at the end of the left side menu control. I am at zero now. A side note. I dynoed the GN on the same day. The rwhp was about 175. Yet the GN is faster in the quarter mile than the 2ss/rs is. The Camaro turns 13.4 while the GN is 13.2 on average. Both are stock except the GN has a gutted cat and stiffer than stock valve springs and a chip. |
