06-08-2017, 07:20 PM | #57 |
Drives: 2017 ZL1 Join Date: Jan 2017
Some photos from doing my ZL1 eLSD fluid swap today
06-09-2017, 08:38 AM | #58 |
雪の玉
Drives: '22 Z71 RST Silverado Join Date: Feb 2011
06-09-2017, 11:46 AM | #59 |
マスタング = 遅い
Drives: 2017 Chevrolet Camaro SS 1LE Join Date: Aug 2015
Pics were posted here too, this is why I want to make a single sticky thread for this...
http://www.camaro6.com/forums/showth...=497475&page=3 |
06-09-2017, 01:25 PM | #60 |
雪の玉
a bunch of different threads, it would make for a good sticky
12-25-2017, 04:55 AM | #61 |
Drives: 2017 ZL1 (M6) Join Date: May 2017
hey guys, need some help, been searching for the Ac Delco p/n 88862624 here in Kuwait and the Ac Delco dealer says its discontinued, the alternative that the Dealer is using is the Ac Delco Supreme plus p/n 88861202 but the only problem is that i'm not sure if it has the modifier, the dealer could be wrong and i just want to make sure before buying the oil, also if you guys recommend something else, btw we don't have royal purple, we do have Lucas and that's about it.
12-25-2017, 12:11 PM | #62 |
Drives: 2016 Corvette Z06, 2018 ATS-V Join Date: Dec 2013
I think it is safe to assume any differential gear lube has the friction modifier unless it specifically states it does not. For instance Red Line has 75/90 gear lube and 75/90 NS. The NS being the nonslip that does not have the modifier.
Perry
16 SharkGrey A8 Corvette Z06 18 Cadillac A8 ATS-V |
12-25-2017, 01:59 PM | #63 |
Passed by lucas oil a couple of hours ago and got the 75w-90 gear oil they have.
12-27-2017, 03:38 PM | #64 |
Drives: 16 2SS 6MT NPP MRC / 15 K1300S Join Date: Mar 2016
Completed my second rear fluid change after another ~10k miles. Almost no discoloration or metal on the magnets compared to the first change at ~2k miles. That first one should be done early.
Rohana RFX-5 10/11, M/T 275/305, Eibachs, Hellwigs, Hurst SS, DMS LT4 SC 596HP/589TQ, DMS Low-side, Kooks 2LTs, MBRP Race, Rotofab, MMS CC |
12-29-2017, 09:49 AM | #65 |
Drives: 2017 Camaro 1LE SS Join Date: Oct 2016
Didn't read all 5 pages but I have to say that you guys started out all wrong. There is no difference from the 1LE/ZL1 rear diffand an SS. Except for the back of it where the e-diff is. It drains and fills identically to the SS.
03-13-2018, 04:14 PM | #66 |
Drives: 2019 ZL1 1LE Join Date: Feb 2017
Update - I had changed out the fluid when I hit 1500 miles. I'm now at 6700 miles, prepping for a track weekend, so I decided to do the fluid again and it actually looked pretty dirty.
Here's the drain plug, it had another good amount of metal dust on it -
Old: 2017 SS 1LE
Old: 2017 ZL1 Current: 2019 ZL1 1LE |
03-13-2018, 07:47 PM | #67 |
Drives: 2020 SS 1LE (previous: 2017 SS 1LE) Join Date: Mar 2012
Indeed these units work hard. I had changed fluidbin mine before and right after a first track day and it was worth it. GM suggests doing it every 20 track duty hrs which I'd agree is a good idea. I do mine together with tranny as well.
03-13-2018, 07:57 PM | #68 |
Also changed trans fluid and went with Amsoil's ATF Signature Series. Made a big difference in how the transmission shifts, much smoother/easier.
Old: 2017 SS 1LE
