01-14-2021, 03:07 PM | #57 |
Drives: 2016 Camaro 2SS Convertible Join Date: Sep 2016
I was pretty much in your same situation at 15k miles and was optimistic that I would not experience the issues others have. However, a few weeks before my B2B warranty expired (time wise, not mile wise), both retractable panels broke. A few months after the B2B warranty expired, I noticed the rear window was starting to delaminate.
1996 Camaro Z28 with T-Tops (Sold 10.22.16) 1986 Camaro IROC-Z with T-Tops (Sold) 1961 Volkswagen Beetle with Sliding Ragtop Sunroof (2009-Present) 1964 Volkswagen Beetle with aftermarket Sliding Ragtop Sunroof (Sold) Follow me on Instagram - @gen6_2ss_vert |
02-16-2021, 06:43 PM | #58 |
Drives: 2017 Convertible 1SS A8 Join Date: Aug 2018
I’m now at 53k miles and my rear window has delaminated for the second time. I’m looking into replacing the flawed gm top with one from GAHH; their site mentions they use a different adhesive for the rear window which helps prevent this issue but it may just be a marketing ploy. If anyone has purchased a top from GAHH in the past, let me know what you thought of their quality.
Kooks 1 7/8" LT catted headers, Katech Ported TB, SoCal ported IM, Green filter, Tuned by BCP, Borla S-Type axle-back, BMR springs, BMR front sway bar endlinks.
02-16-2021, 08:01 PM | #59 | |
Have you thought about trying to pull the glass and apply new adhesive? I just watched a YouTube video on this and it looked pretty simple....Actually, I’m thinking our verts may be easier, since it looks like the glass is set from the outside.(could be wrong on this, but that how I see it). Last edited by Chutzpah; 02-16-2021 at 10:14 PM. Reason: Adding question |
02-17-2021, 07:09 AM | #60 |
Drives: 2017 2SS convertible M6, NPP, MRC Join Date: May 2013
Chutzpah, please post link to that YouTube video you mentioned that showed how to reapply adhesive.
Thanks
Did you hear about the restaurant on the moon?
Great food ------ No atmosphere. |
02-17-2021, 10:07 AM | #61 | |
The videos I’ve seen have some good ideas on how to secure the glass, along with all types of products to use as adhesive. A lot of the products are not what I’d consider the correct application. There are a couple other items to note. I wouldn’t half ass a repair and just try to fix the separated area(s) (as some of them do). I’d have to confirm the routing and and connection point for the rear defrost. Maybe it’s not serviceable. I’m not convinced that the adhesive is totally to blame for all of the separations. Like any opinion, I could be way out of line here. But, my 2016 top was tight as a drum, all the way around the glass (sold it with no separation at 9K). My 2019 has puckers on either side of the glass. In the 2016’s case, this tension puts unintended loads on the sealant, and would be more likely to fail ( in particular under extreme temperatures). I’ve attached a photos, one from my 2019 and two from a thread on this failure. Last edited by Chutzpah; 02-17-2021 at 10:25 AM. Reason: Added another picture |
02-17-2021, 02:48 PM | #62 |
My rear window is coming unglued at what I'm guessing is the inside edge of the window opening in the top, similar to what classicrockr posted here. I do not drive with the windows down while the top is up. From the pictures I've seen posted and the posts I've read, it sounds like most ungluing issues start at the outside edge of the glass.
I did read somewhere on this forum that someone just had the glass replaced or re-glued. Sounds like a much better option than getting the entire top replaced.
02-17-2021, 03:51 PM | #63 | |
Yep, I agree with you on trying to repair, if possible. If I remember correctly, the guy you’re talking about said he had the glass replaced, but when he showed the warranty repair order, it was actually the entire top. Although, I may be wrong... I’m having a hard time buying the adhesive is the sole culprit. If that was the case, we’d be having wholesale failures. The other possibility is poor surface prep before the caulking was installed. Just seeing the difference in top tightness between the cars I owned, kinda made me think...hmmm? Good luck |
02-18-2021, 12:01 AM | #64 | |
And just for anyone’s curiosity the trim shop that replaced my top the last time quoted me $2550 and that’s using a less expensive and terribly flawed oem top not an aftermarket one. I did try the dealer again and they said it’s not covered even though it was replaced under warranty before. I also called GMs customer service helpline and complained and they actually opened a cost assistance case for me but at most that will probably only cover half the cost. If you’re dealing with the same problem out of warranty give GMs main customer service a try.
02-18-2021, 12:19 AM | #65 | |
02-19-2021, 08:31 AM | #66 |
As a last ditch effort I wonder if drilling small holes through the glass and underlying fabric with carbide bits would work. Then very small screws and nuts could be placed to do the main holding. Sealant could be used in between to waterproof. It wouldn't be too pretty but would save a couple of grand for out of warranty cases.
It's just my imagination running away with me...
02-19-2021, 08:54 AM | #67 | |
Thank you Al Oppenheiser!
If I was going to experiment with a DIY temporary fix, I would partly open the top to de-stress the fabric, use a clear RTV like this: https://www.3m.com/3M/en_US/company-...3242013&rt=rud and get some then go for something like these old-school long-reach clamps: https://www.stewmac.com/luthier-tool...cam-clamp.html I did something similar to this hack to buy about 2 years of time with my wife's toyota vert top when the rear glass leaked on her daily driver. By the time the glue fix started to fail, the fabric was shredding from baking in the sun. Not beautiful, but better than duct tape. But the single best thing you can do is find the best convertible top restorer in your area and ask their advice. The one that has been doing it for 20 years and does 2-3 tops a week. At least two Chevy dealers near me send their vert cars to one such fellow for top work. They don't let their techs touch the cars since they'll just screw them up. I had a specialty shop in Bradenton replace my wife's top, and he did a fantastic job. Worth every penny. |
02-19-2021, 12:43 PM | #68 | |
Yep, I’d solidly agree on the highlighted. If was to try a permanent repair myself, I’d probably use a different sealer (but clear silicone is no slouch) The defrost heater looks to be serviceable, I just jumped in the back seat and took a look. It felt like there was a connector just under the interior fabric (you can reach under). I’d probably use these clamps (or at least try to). The reinstallation “looks” like it would be breeze. Of course, everything looks easy to me until I start working on it. With that said, I’d try to remove the glass by first inserting some fishing line through the failure. Then, applying some heat and sawing away. If that wasn’t possible, I’d carefully razor closest to the glass, from the failure area all the way around . It looks like the glass is simply set in a plastic retainer. |
04-26-2021, 05:04 PM | #69 |
18 ZL1 A10 Convertible
Drives: White ZL1 Convertible Join Date: Oct 2016
Ok here is a problem I’m running into today I went to put my top down and it says it can’t because of the divider not being connected. I go to open the trunk and it says I must complete the top down cycle to allow the trunk to open WTH? I can’t open the trunk and I can’t put the top down? Now what anyone have a solution?
2018 ZL1 Convertible A10 @ Kooks R&D. |
04-26-2021, 05:46 PM | #70 | |
Retired from GM
Drives: 2017 Camaro Fifty SS Convertible Join Date: Mar 2017
A8 | MRC | NPP | Nav | HUD | GM Performance CAI | Tony Mamo LT1 V2 Ported TB | Kooks 1-7/8” LT Headers | FlexFuel Tune | Thinkware Q800 Pro front and rear dash cam | Charcoal Tint for Taillights and 3rd Brakelight | Orange and Carbon Fiber Bowties | 1LE Wheels in Gunmetal Gray | Carbon Fiber Interior Overlays | Novistretch bra and mirror covers | Tow hitch for bicycle rack | |
