Old 07-23-2020, 06:49 PM   #1
BlacknRed1990
Drives: 2016 Camaro 1LT 2.0t A8
Running lean under boost at high speeds
Whenever I'm going 50+ mph and I hit boost (About 3500 RPM) I run lean (Popping in exhaust and stuttering/hesitation). Flooring it from 0-40 mph and it pulls great/no problems. I'm still under power train warranty so it'll be the dealership's problem but I'm curious what you guys think it might be. I've only tried cleaning the MAF sensor since that's cheap but that didn't fix it. I have a BNR tune but it has this issue on the stock tune as well.
Current mods: GM performance catback exhaust - JMS PEDALMAX throttle controller - K&N Drop In Air Filter - ZZP Intake Tube - ZZP catted downpipe - ZZP Larger (67mm) throttle body - BNR recirculator valve - Mishimoto intercooler pipes - Mishimoto intercooler - PTP turbo blanket - ZZP flex fuel kit - ZZP big wheel turbo - RX billet stall converter
Flex fuel tuned by ZZP
Tires: Firestone Firehawk Indy 500 245/40/20
Pirelli Winter Sottozero Serie II RunonFlat 245/50/18
BlacknRed1990 is offline   Reply With Quote
Old 07-23-2020, 07:40 PM   #2
wookwook
wookwook's Avatar
Drives: 18 Camaro LS M6
With all you've clearly invested it would have been much better to go the HP tuners route, at least you would be able to actually post something to look at. I think that advise was given some time back iirc.
NFG M6 2T
Mishimoto Hot side pie | ZZP Catted DP | KN Drop in | Borla - Sport Tour | Apex Arc 8 - square | Wookster Tuning+ | Flex Fuel
Last PB
4.8, 13.2@106
wookwook is offline   Reply With Quote
Old 07-24-2020, 05:44 PM   #3
BlacknRed1990
Well I do have EFILive logs, the software is free to download.
Old 07-26-2020, 09:23 AM   #4
wookwook
wookwook's Avatar
noted at least 3 issues on your graphs and returned mark ups. I am wondering if your car had a tune in it before. Are you absolutely sure? I am just asking b/c you said it misfired when you reverted back to the "Original" pull down. I am not about bashing b/c the bnr guy might have kept things in place thinking it was there from before and was working. But- that is a problem with remote tuning, it should have been cleaned up and given a new baseline. But, you have issues that are not hard to fix but it needs a redo.
NFG M6 2T
Last PB
4.8, 13.2@106
