03-29-2016, 11:37 AM | #1 |
Served USN - Atomic Chimp
Drives: 13 Camaro LSX434 TT M6, 21 ZLE A10 Join Date: Jul 2012
ZL1 RDM differential 3.73 or 3.23 gears selection - for turbos
LS3 M6 (6-speed), twin turbos, 3.73
I've been told by "they" that I should raise my RDM gears from 3.73 to 3.23 and I'd get lower 1/8 and 1/4-mile ETs. I've also ran some "benchracing" software and on paper, it confirms it. But you know hypothetical and real life are two different animals. What say ye? Anyone with this/these gear(s) experience?
In excess of 1,000WHP LSX434 | AGP 65/65 TT | BTR Equalizer Intake | Trickflow 245cc cathedral | BTR custom cam | Cortex EBC | n2mb WOT | ID-1700x | Brisk GR12S | RPM Lv 7 TR6060 | AGP's Triple 525LPH Fore Fuel | Monster LT1-S Triple | 4.11 DSS Proform 9", CF driveshaft, 1400hp axles | Hurst Line Lock | MGW Retro Short Throw w/old skool Hurst T-handle | ADM solid subframe mounts | Prothane Motor Mounts | Revshift Poly Trans insert | Moreno camber/caster plates Last edited by dreksnot; 03-29-2016 at 02:55 PM. |
03-29-2016, 12:20 PM | #2 |
Master Amateur Mechanic
Drives: Victory Red 2011 2SS/RS Join Date: Jan 2013
yeah, you'll hook better with twins, not spin through as many gears. have you done any trans mods?
2011 Victory Red 22/RS
Forged 418 Ls3 from Texas Speed, LSX heads from Texas Speed, Tick Turbo cam, Jakes/PCM/Billet 4l80e, 3200 Stall converter from Circle D, DSS 750 hp axles, DSS aluminum driveshaft, stock 3.23 gears, TSW Wheels Front 20x10 Rear 20x11.5, Fabberage Twin Turbo Supercharger Killer kit with Upgraded Turbos, Squash Dual fuel pump, Full BMR Suspension/bushings, Holly High Rise intake manifold, ID1300 Injectors, Megan Coilovers, PCM of NC plug and play trans kit. HP/TQ TBA |
03-29-2016, 12:27 PM | #3 |
Drives: 2010 SS/RS LS3 M6 Join Date: Apr 2011
I'm sure it will help the twins spool up better from having more load on them from moving the car instead of spinning the tires.
03-29-2016, 12:47 PM | #4 | |
I have no trans mods.
In excess of 1,000WHP LSX434 | AGP 65/65 TT | BTR Equalizer Intake | Trickflow 245cc cathedral | BTR custom cam | Cortex EBC | n2mb WOT | ID-1700x | Brisk GR12S | RPM Lv 7 TR6060 | AGP's Triple 525LPH Fore Fuel | Monster LT1-S Triple | 4.11 DSS Proform 9", CF driveshaft, 1400hp axles | Hurst Line Lock | MGW Retro Short Throw w/old skool Hurst T-handle | ADM solid subframe mounts | Prothane Motor Mounts | Revshift Poly Trans insert | Moreno camber/caster plates |
03-29-2016, 01:04 PM | #5 |
Drives: 2010 Camaro RS/2SS Join Date: Sep 2015
You need to take into consideration that you have a stage 3 cam and dropping from 3.73 to 3.23 is going to leave a sour taste in your mouth in 1st gear and low rpm cruising. Load is good for turbos, bad for cams.
2010 Camaro 2SS/RS M6
12.08 @ 115 - 9/2015 (392hp/393tq) NA w/ Exhaust + Tune 11/2015 (464hp/439tq) ^ + BTR Stage 4 w/ Halltech CAI Engine: BTR Stage 4 Cam; BTR Dual Spring Kit; C7R Chain; LS2 Tensioner; High Volume Oil Pump Drivetrain: ACT T2S-G05 x2 Disc XT Street Kit Exhaust: Kook's 1 7/8" Headers w/ Off-road pipes;Kook's 3" cat-back; QTP 3" cut-outs Suspension: BMR 1.4" Front & 1.5" Rear Springs; Blackdog Solid Mounts w/ Poly Bushings |
03-29-2016, 01:10 PM | #6 |
Drives: it changes Join Date: Nov 2010
What size tyres ? What rpm range ? What trap speed ?
And are you managing the 1/4 in 4th gear at present, or shifting to 5th ? Taller gears can help for sure in most cases, but dont go too tall if you dont have the power to back it up. |
03-29-2016, 01:20 PM | #7 |
At first, I had awful bucking and surging below 2,000rpms. I've dialed most of it out with fueling and airflow (still have timing to play with) but still contend with clutching in parking lots below 11mph (1,500rpm). If I switch to 3.23 then that ups me to 13mph for 1,500rpm. Doesn't look like much but going that slow in a parking lot is huge. At highway speeds and low rpms, the cruising has been just fine and am well aware that I'll drop 180rpms at 55mph (from 1370 to 1187) in sixth gear. Might lug and have to downshift back to fifth for 1749rpms. Oh, the dilemma.
03-29-2016, 01:35 PM | #8 | |
The "calculator" says I could knock off a 0.1sec and add 4mph in the 1/8th, and 0.1sec faster but lose 2mph in the 1/4-mile times.
In excess of 1,000WHP LSX434 | AGP 65/65 TT | BTR Equalizer Intake | Trickflow 245cc cathedral | BTR custom cam | Cortex EBC | n2mb WOT | ID-1700x | Brisk GR12S | RPM Lv 7 TR6060 | AGP's Triple 525LPH Fore Fuel | Monster LT1-S Triple | 4.11 DSS Proform 9", CF driveshaft, 1400hp axles | Hurst Line Lock | MGW Retro Short Throw w/old skool Hurst T-handle | ADM solid subframe mounts | Prothane Motor Mounts | Revshift Poly Trans insert | Moreno camber/caster plates Last edited by dreksnot; 03-29-2016 at 02:44 PM. |
03-29-2016, 01:46 PM | #9 | |
I'm in the same boat. The struggle of getting a ZL1 rear end and it being 3.23 or 3.73... Tbh, if you're at 5700 rpms in 4th, you've still got another 1k to go. 3.73s are going to get you to the end faster than dropping gears because you haven't shifted into 5th yet, granted you have the right tires to hook. I can see having to shift into 5 causing you to lose time, but who's going to complain about going 145+ in a 1/4? LOL. 800+ hp and only trapping 11.2? Get you some skinnies and radials! I ran 11.5x at 464hp. You should be in the 9s!
03-29-2016, 02:04 PM | #10 | |
I'm so serious about racing that I leave my subwoofer in the trunk, still have my stock suspension albeit BMR sways (stock alignment), and I enjoy my heated seats and sunroof. Hell, the track is pretty strict so I really can't run full out else I'd be below the 11.5sec ET threshold and I'd get a finger shaking in the face warning me to slow down, or don't come back until I get a rollbar. Would have to do the Drag-n-Dash at the end of the night to see what the car would really do. I'd bet my best time would be 10.9sec with my 4,300lbs heap.
03-29-2016, 02:13 PM | #11 |
Drives: 2006 Z06 Join Date: Oct 2010
I would never gear down like that. Unless you are dead hooking now.
Nick
Corvette Z06 -1200ish rwhp |
03-29-2016, 03:01 PM | #12 |
Nick - are you saying don't 3.73 to 3.23 or the other way around? I have 3.73 now and spinning like a banshee.
03-29-2016, 03:08 PM | #13 |
Why would you go from a 315 to a 275 if you're already spinning? Why not drop to a 17" wheel? (I don't know, I'm just asking.) would that not be any help?
Taco's 2014 SS
Mods: 417 Stroker | CAI | Bo's PTB | Kooks LTs | Flowmaster Outlaw Catback | Night Fury Cam | Powerbond UDP | Apex Catch Can |PRC Ported Heads |FAST 102 Intake |Suspension Crap| Built by J-Rod. |
03-29-2016, 03:20 PM | #14 |
Good question! The 315/40R18's were Nitto NT05R. Just wouldn't hook. I've had recommendation to a little skinnier and taller, and in an M&H. So, better tire, taller but skinnier. We'll see. And my Welds are 18's. I could try a 17 but $$$. Figured the spinning couldn't get any worse.
