08-21-2018, 01:42 AM | #1 |
Drives: 2018 ss Join Date: Jan 2018
Tire help
Thanks for advice in advance. My 18 zl1 is doing 670 rwhp now and I’m needing tires desperately. I talked to my local performance shop that did work and they said I can’t just put dr’s on back. I’m wanting to keep stock rims and was wanting to do Mickey Thompson’s. But was told won’t work. Any advice? There advice was going to Toyo’s all the way around
Sent from my iPhone using Tapatalk |
08-21-2018, 04:58 AM | #2 |
Drives: 20 X3M CP & 19 ZL1 1LE A10 Join Date: Jun 2013
Take the wheels off and take to another shop.
🔺22 RS E TRON GT
🔺21 Model S Plaid |
08-21-2018, 06:53 AM | #3 |
So you’re saying that’s bs in other words just changing back ones will be fine?
08-21-2018, 07:10 AM | #4 |
American Gearhead!!
Drives: ZL1 1LE/GT350/Ford RS/Gen 2 Raptor Join Date: Mar 2013
08-21-2018, 07:41 AM | #5 |
Unless your car is AWD.
🔺22 RS E TRON GT
🔺21 Model S Plaid |
08-21-2018, 08:29 AM | #6 |
That’s kinda what I was thinking what size would y’all recommend since apparently I can’t trust what that shop says
08-21-2018, 08:29 AM | #7 | |
Its all about wording I guess. Maybe that's what he was talking about, but didn't put it in a way for the OP to understand? People saying stuff "wont work" without the explanation can cause confusion. *Sidenote: I'm pushing 800rwhp so not sure if all that comes into play either but I was still told what's seen above as the reason for the two tunes. Plenty of pics of the DR setup on my Instagram: Bianca_ZL1 |
08-21-2018, 08:47 AM | #8 |
drag radials rear and stock tires front is fine. They are possibly thinking about the known bad combo of mixing bias ply & radials. I have run rear bias ply like ET streets and front radials too with no issues. Get a drag radial like an NT05 or Mickey Thompson SS and you will be fine.
08-21-2018, 11:59 PM | #9 |
Drives: 17 black 6m < 18 garnett a10 Join Date: Sep 2017
do an nt05r in the back and nt05 in the front. problem with just doing just a radial in the rear is the difference in sidewall stiffness with the front stock goodyears(radials being soft goodyears being hard); making the car feel loose or unstable at higher speeds. tons of threads on the forums if you look it up
08-22-2018, 07:47 AM | #10 |
The sidewall thing is true to a point but it mostly has to do with air pressure in the rear tires being too low compared to the front tires.
08-22-2018, 09:03 AM | #11 |
Drives: 18 ZL1 nightfall grey A10 Join Date: Apr 2018
Puting DRs in the back and keep stock fronts is more common than not. You should have no problem unless the size is dramatically different from the stock size (maybe).
08-22-2018, 11:35 AM | #12 |
Drives: 2017 Ford F250, 2019 Lincoln Navi Join Date: Apr 2016
Put on the Toyo R888r's and don't look back. I promise you'll be satisfied.
Instagram: MattZ_L1 Vengeance Racing Built
08-22-2018, 12:30 PM | #13 |
08-22-2018, 12:40 PM | #14 |
I did a half mile event with an nt05r in the rear. First at 35 psi then again at 26 and the car was all over the place for both @156mph on my last bolt on car. The lower psi felt better but I wouldn't do it again
