Roto-Fab
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Technical Camaro Topics > Camaro DIY & HOW-TO instructions & discussions
Old 09-05-2009, 06:07 PM   #1
ASTEDA
Drives: 2SS 6M/CGM
Amp install - how to (w/pics)
I've seen a lot of posts asking how to install an amp in the 2010. There are a lot of answers, but none had any pictures. So I decided to document my own install so others can get an idea of how it's done.
Pic 1. Locate the wires to the stock amp. They're on the left side just behind the rear wheel well.
Pic 2. Find the white wire and splice it with your amp turn-on wire.
Pic 3. Pick up an "adjustable output adapter" from your local car audio place. This one cost me $30.00.
Pic 4. Splice the right and left speaker wires with the right and left wires on the output adapter. Sorry for the poor pic... but you can see the RCA outputs on the adapter. Hook your RCA's up and run them, along with your amp turn-on lead, along the back of the trunk and into the spare tire well.
Pic 5. This is the complete hook up of the wires. If you notice the bottom left of the pic- you'll see the RCA wires and the amp lead. I just ran them up the same spot as the power and grounds for the amp.
Pic 6. Finished project.
I also added a lot of dynamat around the trunk to include the top of the trunk door.
I hope this helps a few of you out.
ASTEDA is offline   Reply With Quote
Old 09-05-2009, 06:09 PM   #2
Ject
aka Patrick
Ject's Avatar
Drives: '10 Camaro 2SS '04 Silverado
Send a message via Yahoo to Ject
Pictures are broken links
Current Modifications: Your average Bolt-ons & Suspension Upgrades
GForce Engineering: 9" Rear End, Strange Pro Iron Case w/Moser Nodular 3.70:1 Detroit locker, 3.5" Solid Drive Shaft
Ject is offline   Reply With Quote
Old 09-05-2009, 06:36 PM   #3
ASTEDA
Drives: 2SS 6M/CGM
Fixed
Old 09-05-2009, 08:54 PM   #4
oachalon
Drives: 2010 Camaro 1SS
not bad but not a fan of the duct tape.
oachalon is offline   Reply With Quote
Old 09-05-2009, 09:24 PM   #5
montej23
montej23's Avatar
Drives: 2011 VR Camaro
yeah the duck tape is not a good thing its like its rigged, if your going to do something like this do it right. Because if there is exposed wire it will short out and cause more isues, use the splicers and connectors to do this.
montej23 is offline   Reply With Quote
Old 09-05-2009, 10:46 PM   #6
ASTEDA
Drives: 2SS 6M/CGM
The duct tape was used over electrical tape because it literally melts together after about 10 minutes. There are no exposed wires in the pictures. I've been installing car stereos for over 15 years and have always used this method with zero "shorts".
Also, the stock wires are VERY tight and VERY thick. The only way to connect them after you cut them using connectors and splicers is to add another length of wire to each lead.
This was simply a quick post to show people out there how easy it is to do. They can make it prettier on their own if they want... but it sure as hell beats paying a shop over $200.00 to do it.
Old 09-06-2009, 03:05 AM   #7
LS3SSRS
LS3SSRS's Avatar
Drives: 2010 IBM SS/RS
ASTEDA, i have an adjustable output adapter as well, but mine is adjustable on each channel. in other words, left and right speakers have adjustable gain screws for the RCA outs. was yours the same? and if so, how did u accurately set the gain the same for each? just to what sounds good?
**sold** 2010 2SS/RS, 6spd manual, imperial blue metallic w/black leather
Blacked out tail/signal lights, 5% rear tint, 20% sides, Dynomax Bullet mufflers, Barton short throw shifter, Clear Image offroad downpipes
LS3SSRS is offline   Reply With Quote
Old 09-06-2009, 03:12 AM   #8
my2010camaross
ss
Drives: all black ss
It is funny how some one put s their own time and effort in to giving the forum useful information, then corrected by some one who does nt even have their car yet. Thanks to the original poster. One question, I did not get the boston upgrade so what are my options? I can do it my self, just would like to know exactly what to look for.
my2010camaross is offline   Reply With Quote
Old 09-06-2009, 10:45 AM   #9
ASTEDA
Drives: 2SS 6M/CGM
Yes, my adapter was the same. I adjusted mine to about half... that way I keep the amp at the lower settings. With my amp (850 wt/mono) and enclousures (thin) I could have done about a 1/4 turn less to have been spot on. Currently, I have to play it pretty loud to get the mids and highs to come out clear. I'll change it up when I'm done making my custom boxes.
In the end it'll depend on your amp and subs. Just play with it before you tuck it away. If your adapter is like mine you'll have to turn the up the gains for the amp to work. The first time I tested the system I didn't adjust the gains and the subs were almost silent.
Old 09-06-2009, 10:52 AM   #10
ASTEDA
Drives: 2SS 6M/CGM
I'm not sure what the setup looks like in the cars without the BA system. I think there are a few posts about people hooking into the wires that go to the 6X9's on this forum. The output adapter will work either way... and it doesn't need power or a ground so that makes it pretty easy. Just look at the second sticky on this forum to find the color codes for the wires leading to the rear speakers and make sure you have some good speaker wire handy so you can run a little extra length when you splice.
Thanks for your comment- like I said, this was just a basic "how to" so people could get a visual.
Old 09-06-2009, 11:05 AM   #11
THUMPER20X
GM fix my PAINT U suck!
THUMPER20X's Avatar
Drives: 2010 Black 1SS/RS 6Spd
Good thread. I would suggest getting the fuse right beside the battery. If that lead end going to the fuse comes loose and hits the spare tire well you'll be arcwelding.
THUMPER20X is offline   Reply With Quote
Old 09-06-2009, 12:56 PM   #12
Iwantone2
Voice Of The Voiceless
Iwantone2's Avatar
Drives: CGM 1SS RS
Cool, thanks for the explanation and the pics!!!
Iwantone2 is offline   Reply With Quote
Old 09-06-2009, 02:46 PM   #13
Steve@Subthump
Drives: 2011 2SS IOM Vert
All of this is already included and detailed in our 5th Gen kits to eliminate any guesswork or the need to decipher a wiring diagram. We did all this for you and put it into a kit. We have kits for both the BA system and Non BA system. The non BA system has a special amp trigger since there is no factory 'remote' wire to feed off of.
www.********.com/5gamp.htm
Steve@Subthump is offline   Reply With Quote
Old 09-06-2009, 03:43 PM   #14
ASTEDA
Drives: 2SS 6M/CGM
I didn't see any pictures other than a picture of the amp, Steve... so it's not been "detailed" to anyone unless they pay for your kit.
However, $60.00 is a pretty good price for the kit for someone who is starting from scratch ($9.00 for shipping is a bit much, IMO), but for the people who already have the equipment it ain't doing much to help.
Amp install- how to (w/pics) ASTEDA Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 63 02-27-2017 01:27 PM
My JL 12" and JL 250 amp install VIDEO AND PIX! TAG UR IT Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 55 02-12-2011 01:03 AM
Stereo GUIDE ALL READ WildBeast15 Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 29 09-11-2010 01:14 AM
Updated Kicker 10" L7 and 750 watt amp install klove Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 5 07-18-2009 04:59 PM
PLZ INSTRUCTION HOW TO INSTALL AMP AND SUB Terrellford12 Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 14 07-03-2009 06:17 PM
