04-16-2021, 07:10 PM | #1 |
Drives: 2016 Camaro Join Date: Oct 2017
Aftermarket Differential
I would like to know if anyone had installed an aftermarket differential? If so, what is your experience and what kind did you get?
The two common ones I know of are both nine-inch. One is from Gforce Engineering (gforce1320.com) and the other setup is from “The Driveshaft Shop” (driveshaftshop.com) Prices are fairly close. Thanks!
2024 Chevrolet 3500HD Z71, LTZ, 4x4, 6.6 ltr. L5P long-bed.
2016 Camaro 2SS Six-speed, Hotchkis sway bars, Eibach .750" drop springs, Mamo throttle body, E85, BMR stuff. 2006 Quicksilver 6-speed GTO ERL LS3-430, All-Pro 285cc heads, 262/273 .758/.742 116+3 cam, Sheet-metal Intake, 70lb Siemens injectors, SLP, GMM Ripshifter, QA1 Coil-overs front and rear, nylon suspension bushings, Hotchkis, RPM Trans, SPEC twin clutch, SpinTech, Kooks 1 7/8 -2.0", BMR drive train, Kaaz 3.91, Lingenfelter CAI, Baer brakes, mini-tubs, E85. |
05-28-2021, 01:40 AM | #2 |
Drives: 1SS Summit White 6 speed Join Date: Jul 2017
A set of 4.10 or 4.30 gears would be great
Aftermarket for these cars can get absurd though Try a set of 18's It'll definitely help
16 1SS M6 White
Magnuson 2.3 Heartbeat Roto Fab Solo Performance Cat deletes and Axleback Hurst short shifter #'s coming soon Riaction coilovers 1LE sway bars BMR mm BMR chassis brace Flow one 19" wheels wrapped in Mickey Thompsons 02 Z28 M6 35th anniversary 80k miles T-tops Leather Bolt ons Joy to drive this classic every day! Daily Driver |
Thread Tools | |
