View Poll Results: Who has experienced an oil pump failure? | |||
2016 or earlier | 20 | 13.79% | |
2017 | 53 | 36.55% | |
2018 | 67 | 46.21% | |
2019 | 2 | 1.38% | |
2020 | 2 | 1.38% | |
2021 | 1 | 0.69% | |
Voters: 145. You may not vote on this poll |
Thread Tools |
04-16-2021, 09:05 PM | #729 | |
Drives: Track prepped 2018 Camaro ZL1 (a10) Join Date: Aug 2013
No offense but it doesn’t appear you know who makes the pump so how do you know it’s been fixed? Katech oil pump is definitely made with better materials and it does not void the powertrain warranty at all, I checked with the dealership already. Plus the price of the factory oil pump gets put towards the cost of my new oil pump and I pay the difference, so it’s not much more money. On top of that I track my car hard and the last thing I want is the potential of blowing my engine regardless of the fact it would be covered by warranty. Who wants to be thinking about that while they are up against Porsche gT3 or trying to set a new PB?
2018 ZL1; Mag 2650 and 2 inch LT Headers , every SPL suspension upgrade, MCS 2 way coilovers, sway bars, square SC3R 325's all the way around, and multiple brake cooling upgrades
04-16-2021, 09:07 PM | #730 | |
I’m not taking any chances with a pump proven to fail
04-16-2021, 09:11 PM | #731 | |
I’m not willing to “bet” the stock OEM pump is now great without proof that it’s flawes are fixed. The only thing not covered under warranty will be the Katech oil pump itself, and of course if that pump failed, any resulting consequences.
04-16-2021, 10:18 PM | #732 | |
Drives: 18 ZL1-1LE, 10 JKU Join Date: Jul 2018
I also thought melling made them, guess they just make the cam phaser gear? Also, looking at the date ranges for failures, you could make an assumption they did revise it as there weren’t any reported failures that we’ve seen after a certain point. However, if Katech says it’s still an issue, then i guess we probably have reason to think not much has changed. |
04-17-2021, 01:13 AM | #733 | |
Drives: 2018 Hyper Blue ZL1 1LE Join Date: Dec 2018
Also, I don’t agree that the stock spec Katech pump (vs higher pressure version they also make that requires a tune) is not meant for someone with advanced mods and more power—higher stress and heat from more power affects everything in the engine and oiling system. Hence a more durable billet parts pump is better for a modded car, or race car, assuming it is actually more reliable and less prone to failure under heavy duty use like maybe an endurance race. In that case I too might opt for the CNC billet steel gear Katech pump, like if I get a Katech stage 5+ package. My other point, as I think you stated above, is that if the Katech pump fails your motor is not covered, and considering you seem to have a warranty this doesn’t seem like a good choice IMO. If you are planning mods that will void your warranty, it may be a very good idea. |
04-19-2021, 12:02 PM | #734 | |
Since my just failed now, perhaps it just hasn't been long enough for the 19's to start failing in any significant number?
04-19-2021, 12:42 PM | #735 |
Drives: 2018 ZL1 Coupe NFG M6 Join Date: May 2017
Speaking of oil pumps, got an email from Katech that says mine is shipping! Makes me feel a little better.
1989 Forumla 350 WS6 <- High School
2000 Trans Am Firehawk <- After High School 2017 Colorado Z71 <- Daily 2018 ZL1 M6 <- Not Daily |
04-19-2021, 01:24 PM | #736 | ||
Drives: 2019 ZL1 Riverside Join Date: Apr 2020
If GM can't build a reliable oil pump that's pretty sad. I watch my oil pressure like a hawk, it should always be about 40 or above. Variable vane design seems to be a weak point |
04-19-2021, 09:26 PM | #737 |
Drives: ZL1/1LE parts added Join Date: May 2018
Location: Somewhere around Texas pines tress and smooth asphalt
I imagine the oil pumps are made by a outside company, I'm in the middle of changing my 5.7 toyota tundra water pump, the 1st change out was at 100K, now I have 227,000 I believe it started miles ago, what's interesting is I saw a water pump of a dodge caravan one day that was extremely similar.
Here's my question? Is gm using this pump on all there vehicles? And does the supplying company make that same oil pump for any other automaker ? Maybe some one can give more insight on why they fail ! |
04-19-2021, 10:15 PM | #738 | |
and 25 hours, yeah, i don't blame them for charging that after seeing what all is involved to swap out a $130 part lol(or $500 for the katech, but ya get my point) |
04-20-2021, 03:54 AM | #739 |
Drives: Camaro ZL1 Join Date: Apr 2019
Do you have to pull the motor to install the pump?
Made in the USA. Refined in Great Britain - insta: zl1uk
Velossa intake, Rotofab, Mamo TB, Custom ported NX Lid & Jokerz Full tilt ported LT4 charger, 3 port CoolingMist Meth injection - ATI 15% lower pulley, E2X CC, TSP ceramic coated longtubes, de-cat and Borla 60608 to NPP box, JRE tune, BMR rear control & trailing arms, lock-out kit, lowering springs and front strut brace, Custom carbon trim interior, Xpel ultimate front PPF and Prestige window tint with Chameleon Windscreen tint...ever evolving... |
04-20-2021, 04:55 AM | #740 |
Former GM Technician
Drives: 2018 ZL1 A10, 06 Silverado Duramax Join Date: Sep 2009
Hello Gary. You don't have to pull the motor.
You can just lower the front cradle, to be able to remove the oil pan.
2018 Camaro ZL1 A10
Rotofab Big Gulp, Nick Williams 103, Magnuson 2650, 9.17" (14%) lower, 90mm upper, Vengeance Racing Heads (LME) Cam Package (Cammotion Stage 1), Johnson Lifters, JMS Voltage Booster, Lingenfelter high flow check valve, BBK shorty headers, Custom 2.75" down pipes, Gesi Gen2 high flow cats, MM catch can 791whp, 772ft-lbs SAE Just added 30% XDI Injectors, LPE big bore hpfp, Flex fuel. Elite tuning, results coming soon. 2006 Silverado Duramax Diesel MPI Compound Turbo 40% over Injectors Efi Live DSP5 Tuning Follow me on Instagram: Swisstyphoon1980 |
04-20-2021, 12:12 PM | #741 |
Drives: 2013 ZL1 Join Date: Oct 2011
boy looking at used zl1's did not know this was still an issue.
I did two 5th gen oil pump replacements. when I pulled them apart the bypass check valve was stuck open. since I am more a shadetree mechanic and don't have good magnification or anything I would never decide if it was debris or tolerance issue. both I could free up but both cars got katech pumps back in and to this date are good to go. I have owned multiple cars with this style pump and never had the issue myself. now my brain went two places 1. debris 2. as metal gets hot it is expands and if tolerance is two tight maybe it stuck. both cars were being driven hard and then basically it stuck in between track sessions. one car was at road corse and one car basically did two half mile hard pulls back to back. one car was LS3 stock the other was LSA 630whp.
shopping for 2017+1le or zl1
2009 CTS-V -sold 2015 Hellcat-sold 2013 ZL1 -sold 2007 Z06- sold 2014 Chrysler 300 2011 Duramax 8" lift, deleted tuned |
04-20-2021, 02:47 PM | #742 |
Thread Tools | |
