10-28-2018, 09:33 AM | #1 |
Drives: 2017 Hyper Blue 2SS Join Date: Mar 2017
DBA 5000 T3 at Tirerack
Are these rotors a replacement for the Brembo 6 piston factory brakes?
https://www.tirerack.com/brakes/brak...oModClar=Coupe Thanks
Hyper Blue 2SS, 6MT, NPP, 6 piston Brembo, 1LE suspensions upgrade, ZL1 Seats, Wheels & Tires
10-29-2018, 07:45 AM | #2 |
Drives: 2017 1SS 1LE Join Date: Jun 2016
For the SS 1LE 6-piston brakes, yes they fit. See here.
For the ZL1 and ZL1/1LE calipers, they don't fit because the rotors are a larger diameter. Best way to confirm is to look at the PN engraved into the rotor or measure the rotor. If you're at 370 mm rotor diameter or have PNs 23142500 (LH) and 23189768 (RH), they'll fit.
2017 SS 1LE.
10-29-2018, 08:02 AM | #3 | |
11-01-2018, 06:28 AM | #4 |
Looks like the rotor ring will fit but the hat is wrong, according to glamcem's post that was linked. Searching on Tire Rack for the 1LE gave no result either. Seems to me, the thing to do would be to get just the rings like glamcem did.
