07-16-2019, 06:56 PM | #15 | |
Drives: 2016 Camaro SS Join Date: Sep 2018
If I can get 750 rwhp out of this set up I'll be happy until I forge it. Sent from my SM-G955U using Tapatalk |
07-16-2019, 11:39 PM | #16 |
Makes sense...look forward to your results.
2016 NFG 1SS A8
07-19-2019, 04:32 AM | #17 | |
Drives: 18 1SS 1LE HyperBlue Join Date: Aug 2018
Lets say you put a out of the box P/C setup on a stock engine and tune it and its running 10lbs. A year later you do do a cam, headers, and intake manifold. Since the engine is able to flow much more CFM, the restriction is less, so boost will go down on the gauge, but CFM is going up (and making more power). I am over 700wheel (SBE, stock cam, stock intake, LT4 fueling, E85, and a little meth) and have yet to see over 10lbs
2018 1SS 1LE / HBM - ECS Novi 1500 S/C Tuned by Carl @ CJ Tunes
07-19-2019, 05:05 PM | #18 | |
