04-07-2017, 02:00 AM | #1 |
Drives: 2016 V6 Summit White/Adrenaline Red Join Date: May 2016
offset question help!!
so i purchased some 20x10 ET45 wheels for front and back
i havent received them yet but just wanted to ask you guys if they'd fit both front and back with that 45 offset? and any recommendations on what size tires to get? |
04-07-2017, 09:54 AM | #2 |
Drives: SS-6-SPD Join Date: Jan 2017
you will need +25 for the front to caliper the caliper...
04-07-2017, 12:39 PM | #3 |
SABIO
They will fit in the back as long as you have caliper clearance.
You will need a 20mm spacer up front. But if you do that it would look awkward with the front pushed out to the fender so you would have to add a 10-15mm spacer in the back. Wheels were are good deal? Now you have to spend more on spacers and maybe studs. 285/35/20 squared on the 10". You can do 275/35/20 as well.
04-07-2017, 01:17 PM | #4 |
Drives: 2017 Chevrolet SS 1LE Join Date: Oct 2016
What wheels brotha? the offset seems too high IMO
Front needs to be a ET 23-28 rear preferable in a ET 25-37 depending on the concave profile the cap wont fit because of the axle bolt that sticks out the hub. |
04-07-2017, 04:36 PM | #5 |
Vossen cv7 20x10
I got the set 900 shipped I was so skeptical on buying them because of the offset but the price was too good I just hope they'll fit, I'm going to try the 20mm spacers in the front and 10mm in the back to see how they look |
04-08-2017, 12:32 PM | #6 |
Your going to need a adapter brotha.
