TireRack
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Technical Camaro Topics > Camaro DIY & HOW-TO instructions & discussions
Old 11-30-2009, 12:22 AM   #29
2SSRS@Gen5diy
2SSRS@Gen5diy's Avatar
Drives: 2014 Z/28 #82+#192, 18ZLE 66Nova
Originally Posted by Jakefeb3 View Post
No 1ss doesnt have abl in the doors. Thats whats causing me grief. i opened up the driver side fuse bezel and was looking for the power connection that was used here:
http://www.camaro5.com/forums/showth...&highlight=abl
But aparently 1ss doesnt even have that cable. If someone who has a 2ss could figure out where this cable connects to, that would be totally killer info to have. If I could figure out where this cable connects to, maybe I could just wire my own
It comes from the dimmer Switch.
2SSRS@Gen5diy is offline   Reply With Quote
Old 11-30-2009, 12:24 AM   #30
Jakefeb3
Drives: 2010 camaro 1ss
the dimmer switch info was my first thought when I was thinking about how to do this. But I think all those connections are just sending data to the bcm(or something)
Jakefeb3 is offline   Reply With Quote
Old 11-30-2009, 12:25 AM   #31
Jakefeb3
So which pins are they?
Old 11-30-2009, 12:27 AM   #32
2SSRS@Gen5diy
Headlamp and Panel Dimmer Switch info
Old 11-30-2009, 12:30 AM   #33
Jakefeb3
In this photo, it looks like a purple wire and another(?) wire
Old 11-30-2009, 12:32 AM   #34
Jakefeb3
The only thing I see thats purple in the diagram is the foglights, but I dont think that is right. I dont see anything related to the ambient lighting or anything like that. Any thoughts?
Old 11-30-2009, 07:16 AM   #35
TonyNo
TonyNo's Avatar
Drives: 2016 2SS, SW
Originally Posted by daphatgrant View Post
What size fuse did you use?
3A (smallest I could find). My strips draw 0.07A each.
TonyNo is offline   Reply With Quote
Old 12-01-2009, 08:55 PM   #36
cybercoaster
cybercoaster's Avatar
Drives: 2017 2SS 50th Anv, 1972 RS
Thanks TonyNo. I hope to wire in my CCFL soon
cybercoaster is offline   Reply With Quote
Old 12-02-2009, 02:50 PM   #37
CRZ
Drives: 2010 1LT/RS RJT Camaro
For me it's looking like the best option is to tap off the forward outlet/cigarette power, install a switch that I'll mount to the right of the steering column, and manually turn on the footwell and accent lighting.
The dome switch obviously needs to fade out, and I'd like to be able to have some leds working when the car is rolling. Plus, if you switch out the dome lighting to a highpower color LED, the interior of the car will already show up lit up in your chosen color from the dome light regardless of what your footwells are doing.
I thought about connecting to the headlights, to engage the LEDs whenever the headlights were on, but having the control to turn them on whenever is probably going to work out better for me.
I'll probably get the lights and install them in January, I'll be sure to post up pics when I'm done.
CRZ is offline   Reply With Quote
Old 12-02-2009, 03:14 PM   #38
TonyNo
TonyNo's Avatar
Not quite. Anything in the front 3/4 of the footwell is still dark.
Old 12-02-2009, 03:32 PM   #39
CRZ
I'll certainly grant you that, Tony!
I guess I'm just talking about seeing the car from the exterior, when I engage the dome from the remote.
It's all in what you're looking for. If you need/want your footwell lights for further illumination in the interior to find things dropped or better light the car for entry purposes, the dome light's the way to go.
For me, I always have a flashlight on my person and one in the glovebox, so the dome and footwells are more a cosmetic thing than a utility.
Old 12-02-2009, 09:31 PM   #40
TonyNo
TonyNo's Avatar
Yup. All about what you want.
Old 12-03-2009, 12:45 AM   #41
SummoneR
Paul
SummoneR's Avatar
Drives: '10 2SS/RS M6 "Marauder"
Send a message via Yahoo to SummoneR
Tony, thanks for the write up, I had not thought about hooking it up to the dome light, that works perfectly for what I want to do.
I want the foot well and under the seats in the rear to only come on when I need to find something, therefore attaching it to the dome light works perfectly. My sister has footwell lighting in her Scion, and it's way too much to have on while driving. I plan to do small accents here and there in other area that I plan to connect with a switch, I was hoping to eliminate the number of switches and this works great.
Thanks again!!
SummoneR is offline   Reply With Quote
Old 12-03-2009, 10:42 PM   #42
CarNutzCustomz
Drives: 2010 Camaro 2SS/RS
Looks like GM will be offering a plug and play solution for footwell lighting.
http://www.gmpartsdirect.com/results...umber=92213222
2010 Camaro 2SS/RS
Cyber Gray Metallic/Black
CarNutzCustomz is offline   Reply With Quote
Where to wire in ambient footwell lighting? cybercoaster Cosmetics and Lighting Modification Discussions 32 01-11-2016 11:08 AM
Anyone have the Footwell Lighting Kit Installed? wildthing001967 Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 12 07-03-2011 05:00 PM
AACStyle footwell lighting problem TRSS2 Camaro DIY & HOW-TO instructions & discussions 8 01-23-2010 06:41 PM
footwell neon lighting. How to wire to have it come on the other ambient lighting? Jakefeb3 Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 6 11-22-2009 09:32 PM
