01-23-2024, 02:58 PM | #1 |
Drives: 2023 Camaro SS Join Date: Jan 2024
Can I fit 35 sidewall tires
I have aftermarket wheels and the offset are 20x10 +23 in the front and 20x11 +38 in the rear. My car is lowered on bmr springs which dropped it about an inch. I am wanting to fill up to tire gap hence why I am asking if I can fit this particular tire size. I know a couple of people run this size and am wondering what was needed to be done if any. Thanks!
01-24-2024, 07:56 AM | #2 | |
Drives: 2020 Camaro 2SS A10 Join Date: Jun 2018
20x10 ET20 Front 20x11 ET43 Rear (same as 1LE specs - and accounts for bigger brakes of the 1LE if applicable) I am told 35 aspect is fine on the rear, but I think there was a year cutoff where that is applicable. And not sure if your lowering springs are going to change that either. And our stock fronts are 40 aspect so 35 would be fine on the front. I run 20x10 ET20 and 20x11 ET43 wheels with 305/30R20 on the back, and 275/30R20 on the front (285 can be used as well on the front)
2020 Camaro 2SS A10 | Rebuilt by: CBI Street Cars | 2" SE LT Headers | 3" SE X-Pipe | 3" MBRP Axle-Back | Pri & Sec Cat Deletes | Roto-Fab CAI | LT2 Ported | 95mm ZR1 TB | LSA crankshaft conversion w/modified crank gear | LS1 thrust bearing | LS MSD Plug Wire Set | BTR Stage I Cam | ARP Rod Bolts | Delphi Lifter set | NGK LTR71X-11 spark plug set | DOD Delete | VVT Limiter | ECM, TCM & E85 | Retuned by: Justin L. | Dyno: 510 rwhp 472 rwtq | Best 1/4 Time: 11.639
01-24-2024, 08:15 AM | #3 |
Instagram: Sangstah
35s fit fine on the front with that offset. You will need to possibly move the brake cable on the driver side for the rear, you can search for that thread on how to.
2019 SS 1LE - "CaSSandra" 2014 SS - "AleSSandra - Sold" 94 Z28 - Sold Follow the build https://www.camaro6.com/forums/showthread.php?t=612717 |
