02-18-2019, 02:40 PM | #1 |
Drives: 2016 Twin Turbo Camaro 2SS Join Date: Jan 2019
Lowering under-hood temps
I picked up the Armageddon Turbo Systems Camaro and I need to see what I can do to lower the under hood temps. I am looking at the TS-1 Carbon Creations or the VIS Terminator hoods. I looked at the Carbon Fiber Heat Extractor for the stock hood. I also thought about adding vents to the factory hood. If I replace the hood, I like the look of the TS-1 because it looks closer to stock. The Terminator looks like it is better constructed but more Gotti for sure. Either way, I need the functionality of the exhaust vents more that anything. Does anyone of the forum have luck with lowering under-hood temps? If so, what worked best for you?
02-18-2019, 03:12 PM | #2 |
Drives: 17 SS a8 Join Date: Feb 2010
One thing I did was command the fan to never completely shut off. I think I have it set at 40% min, have to look. I adjusted it to where it didn’t bother me while in the car with it running.
At 100% it is LOUD.
best et 5.83@121 with the 5.3 http://www.camaro6.com/forums/showthread.php?t=465472 |
02-18-2019, 04:31 PM | #3 |
stay away from carbon creations and they make a plug n play module you can buy if you want to tune the fan setting on but not sure what else you could do??
02-18-2019, 05:02 PM | #4 |
You can adjust the fan settings with hp tuners.
02-19-2019, 12:24 AM | #5 |
Drives: 2016 M6 2.0T Join Date: Nov 2016
I'm super bummed Hines Hex Vents is no longer in business.
RS Package, HD Cooling Package, Brembo 6 Piston Front Brakes, SRP Racing Pedals, Soler Performance Throttle Controller, Dyno Tuned by Trifecta, Velossa Tech Ram Air, Mishimoto Intake, aFe Air Filter, Mishimoto Charge Pipes, ZZP 67mm Throttle Body, Trifecta T40 Stage 2 Turbo, JacFab Recirculation Valve, PTP Turbo Blanket, ZZP Catted Downpipe, Mishimoto Pro Cat-Back Quad Tip Exhaust, Mishimoto Catch Cans, Mishimoto Coolant Reservoir Tank, GM SEMA Grill, Ikon Motorsports Front Fascia Extension, Ikon Motorsports 1LE Spoiler, American Authority ZL1 Side Skirts, AMPP Quad Tip Rear Valance
02-19-2019, 02:40 AM | #6 |
Drives: 2015 Camaro 1SS Join Date: Dec 2017
What about a Driveway Labs hood duct.
02-23-2019, 02:54 AM | #7 |
You can only YOLO once.
Drives: '16 2SS & '15 Subaru Forester Join Date: Jan 2016
Whatever you do you need to pay huge attention to where you place the vents. I was watching a video the other day watching an engineer explain the good and bad places to place vents and the best location is basically where our stock ones are and where the 19's have their's placed...right at that distance from the front edge is where you need to place the vents to get the best flow out of the bay.
I have been slowly looking into using the stock vents and getting NACA ducts built in to increase the airflow out of them...the stock plastic air routing under the finisher plates is decent but not high flowing...a compromise between flow and not letting too much water into places they don't necessarily want a lot of water dripping to. Did any of that make sense? It's late.
2016 Camaro 2ss
-Summit White / Ceramic White -8A, NPP, MRC, Ceramic White package plus knee pads, black bowties. -1st Car to have the "full" SEMA High Performance Graphics kit from 6LEDesigns. -1st Car to have the 6LEDesigns Blade Spoiler. -Borla S-Type w/ custom H-Pipe -Procharger P-1X Stage 2 |
02-23-2019, 04:00 PM | #8 |
Drives: Gen 6 Camaro IROC-Z Join Date: Dec 2018
We track tested our hoods, with customers across the country, and starting with just our IROC-Z Hood (COPO style) we drop IATs by 13* on average over stock.
If you move into one of our IROC-Z Hoods with Louvers, my IATs were about 13* less than stock and I was running a Whipplecharger... https://irocmotorsports.com/product-...z-brand-hoods/ |
02-01-2020, 05:05 PM | #9 |
Drives: 2017 ZL1 Join Date: Aug 2016
Killer chiller. 1500 bucks.
02-14-2020, 07:48 PM | #10 |
Drives: 2017 Camaro 2SS Nightfall Gray 1LE Join Date: Mar 2017
maybe a small high CFM fan under each hood vent? You could have them turn on based on temp or via a toggle switch.
02-15-2020, 08:48 AM | #11 |
Drives: 2016 2SS Join Date: Feb 2010
The cheapest (and tackiest) way is to raise the back of the hood with washers. This is an old, old fad that was used over 60 years ago by old muscle car owners. If you dont mind having a car with a missaligned hood, try it and see if it works on the 6 Gen.https://my350z.com/forum/engine-and-...l#&gid=1&pid=1
2016 Hyper Blue 2SS, A8, NPP, MRC
