05-21-2021, 08:51 PM | #43 | |
Drives: 2016 Challenger Hellcat, 2018 ZL1LE Join Date: Dec 2009
Here is my advice, if you really like that car and would like to keep it, I would remove whatever aftermarket mods you may have done to it (if it's not too late, since the dealership already looked at the car). Then I would drive THE HELL out of the car until the oil pump or something else gives out. Then bring it to the dealer and get a new motor put in under warranty. If you never really intended to keep the car for a long time, then sale it while you can. Just be as upfront about your issue as possible. Make a decision either way soon while you still have plenty of warranty left. Good luck and keep us posted.
2018 ZL1 1LE/Red hot 2019 Shellby GT 350R/ Oxford white/ Matte Black Stripes/ Carbon Fiber Dash/ Electronics Package #413 |
05-22-2021, 02:40 AM | #44 | |
Drives: Camaro ZL1 Join Date: Apr 2020
I have tested this and it works. Pic below is the table calibrated to bring on the warning at oil pressures below 50psi at 512-1024 rpm. This was done as a test. Second pic is it working, oil pressure is at 32psi however due to the minimum warning set to 50psi at idle rpm the warning chime/display comes up. You can re-calibrate these rpm thresholds higher than the OEM settings to give earlier warning of possible oil pump failure. |
05-22-2021, 12:44 PM | #45 |
Sarcasm loading --------
this is from the manual.
2018 MBM ZL1 1LE - Stock 2014 CRT ZL1 574 rwhp, 537 rwtq - SOLD 2010 IBM SS Camaro VVT L99 w/ TR6060 swap, 489 rwhp, 444 rwtq - SOLD |
05-22-2021, 01:31 PM | #46 |
Drives: 1985 Z28 Join Date: Aug 2020
Take it to CarMax and get rid of it before it blows up.
You can get top dollar for it. $$$$$ Or trade it in for C8 Vette or GT500. |
05-23-2021, 12:25 AM | #47 |
Drives: 2017 ZL1 A10 Summit White Join Date: Apr 2018
Just keep in mind that just because the pump fails, doesn't mean the engine is done. Mine failed and they put a new pump in and it's been fine. Don't stress about it.
05-23-2021, 09:07 AM | #48 |
Drives: 2023 SS 1LE Join Date: Mar 2020
Disappointing response from GM. It’s lower then their own designated lowest safe oil pressure and they still deny anything is wrong. But, not surprising.
Just out of curiosity, how much would it cost to pay out of pocket to have the pump replaced with an updated version? Might be a way of keeping a rare and otherwise excellent car with confidence. I mean, guys will spend $2k-$3k for a paint correction, PPF application and ceramic coating appointment and that is purely cosmetic. Also, if you paid the dealership to remove and replace the pump, and then have the faulty pump in hand, with visible proof of the cracked gear, couldn’t you then revisit GM warranty services with irrefutable evidence of the defective pump and request reimbursement? Just ideas. That’s what I am working out in my head in the event I find myself in a similar situation as you. |
05-23-2021, 10:18 AM | #49 |
Drives: 2020 SS 1LE Join Date: Aug 2020
mine is a 2021 with 1,000 miles now. Changed oil at 500 miles and now at 1000 miles. I noticed that when I swapped to 15-50 since ill be tracking it next weekend. my hot oil pressure dropped. What kind of oil are you using? I put mobil 1 15-50 and now its much lower than what it was with ESP 0-40
05-23-2021, 10:21 AM | #50 |
Also we do some logging and oil pressure doesn't spike above 40 until about 6,000 rpms and up.
05-23-2021, 11:00 AM | #51 | |
this car is a toy for me - i drive it maybe 4 times a month, and take it to the track 2+ times a year. a concern of mine is what will happen the next time I change the oil to 15w-50?
05-23-2021, 01:11 PM | #52 |
Drives: 2019 ZL1 Riverside Join Date: Apr 2020
17s and 18s are probably all ticking time bombs, most owners don't put many miles on these cars - who knows, 19+ could be next
05-23-2021, 02:11 PM | #53 |
05-23-2021, 03:34 PM | #54 |
I agree Chutzpah!
05-23-2021, 11:16 PM | #55 | |
Drives: 2019 2SS Camaro Join Date: Apr 2012
mines a 19 ss and already had the lates pump from gm |
05-24-2021, 06:43 AM | #56 |
Oh Oh it's Friday Night!
Drives: 2018 ZL1 1LE Nightfall Gray Join Date: Jan 2018
Do we know for sure when GM began to make changes to the oil pump, how many changes were involved and the months/years these changes were made. At one point there was a discussion that the oil pump was changed in late 2017 I believe, but failures after that time period have continued to be documented. Mine is a January 2018 build and, although my oil pressure has always been good, never any hiccups, I am always concerned about the odds that I have a ticking time bomb too.
Four that wanna own me Two that wanna stone me One says she's a friend of mine... |
