TireRack
Old 12-18-2013, 08:17 AM   #15
Apex Motorsports
Apex Motorsports's Avatar
Drives: 2000 Camaro SS
Originally Posted by RenegadeXR View Post
5000k lights would be just ever-so-slightly bluer than the HID headlamps, right? 4300k is the way to go for an exact match?
4300k is what we used and it is a dead match.
Apex Motorsports is offline   Reply With Quote
Old 12-18-2013, 08:45 AM   #16
LuSe4
LuSe4's Avatar
Drives: 2013 Camaro 2SS RS LS3
I have 4300K on mine and they are a very close match. They look sooooo much better than the factory bulbs.
Comparing factory vs. LED. Notice how much brighter it appears. They actually put out enough light that you could drive around at night with the headlights off and still be able to see somewhat.
Both bulbs in.
-2013 Summit White over Inferno Orange 2SS RS-
-2014 White Diamond Silverado Z71 Crew Cab Short Box-
LuSe4 is offline   Reply With Quote
Old 12-18-2013, 11:43 AM   #17
Apex Motorsports
It definitely lit the bay up more and it just made the car look like it was a higher end vehicle.
Old 12-18-2013, 11:59 AM   #18
Dexman1349
2010 2SS/RS M6
Dexman1349's Avatar
Drives: 2010 2SS/RS M6
Originally Posted by Apex Chase View Post
Today we installed 4300K LED DRL bulbs (DIYP13W754300K) and the DRL harness (DIYDR1) to keep the DRL's on with the headlights on Paul's car.
Man! What a big improvement!
From a cosmetic standpoint it looks a lot better but also in the shop with the overhead lights off you could immediately see more light.
How do these compare to the ZL1 fogs?
I currently have a 2010 2SS/RS that I'm doing the ZL1 conversion for. Obviously the RS fogs would get this bulb, but what about the 2nd set of ZL1 lights?
2/7/2014: 419 hp, 419 tq
Cosmetic: ZL1 front w/mailslot, painted stripes, powdercoated SS rims, tow hook, and full chrome delete
Suspension: Pfadt subframe bushings, Pfadt rear UCA bushings, Z28 Upper control arms, Spohn trailing arms with BMR trailing arm & differential bushings, ZL1 Toe Rods and springs, Prothane radius arm inserts & steering rack bushing, Pfadt Sport front sway, FE4 conversion w/ DS rear sway, Pfadt strut brace
Drivetrain: RMCR tune, CAI intake, Kooks headers, hi-flo cats & exhaust, VMAX TB, ZL1 fuel pump, LSR Tri-Ax shifter
Bumblebee Racecar Build
Dexman1349 is offline   Reply With Quote
Old 12-21-2013, 05:50 PM   #19
Apex Motorsports
If you go on our website in the ZL1 side there is a lighting section. They are all listed there.
Old 12-22-2013, 05:34 AM   #20
AbsoluteMayheM
LongTimeLurker
AbsoluteMayheM's Avatar
Drives: 2011 SIM 2SS/RS Convertible L99
They are available on our website. Let me know if you need a link.
Link Please!
2011 2SS/RS
AbsoluteMayheM is offline   Reply With Quote
Old 12-22-2013, 07:26 AM   #21
heymatt
heymatt's Avatar
Drives: 2012 IBM 2SS Vert.
I did the 5 k bulbs. To me they were a closer match. Big difference when driving and it looks like it should have when GM built it.
LS3/M6 K&N, VMAX throttle body, RX Catch Can, skip shift eliminator, DT shorties and Solo HFC, DRL harness and 5K LED DRL, ZL1 rear sway, 1LE front sway
heymatt is offline   Reply With Quote
Old 12-22-2013, 09:18 PM   #22
Little Blown Blue
Little Blown Blue's Avatar
Drives: 2010 Blown Blue Camaro
Anyone bypass the DLR lights or should I say, added a switch to turn them on and off manually? Mine turn off when the headlights come on and there is no switch to turn them on.
2010 2SS
TVS2300
Full exhaust
Full suspension
20" Vossen VS2's
Pirelli P-0's
Little Blown Blue is offline   Reply With Quote
Old 12-22-2013, 09:24 PM   #23
I've got a switch on my DRL's but it came with the harness I bought.
http://www.camaro5.com/forums/showpo...&postcount=222
Old 12-22-2013, 10:36 PM   #24
MedicalCowboy
Save lives? Hahahahaha
MedicalCowboy's Avatar
Drives: An ambulance, a 2ss/rs, x-wing
With these bulbs can you see each individual led?
MedicalCowboy is offline   Reply With Quote
Old 12-23-2013, 09:19 AM   #25
ddunerider
So-Cal Race team!!
ddunerider's Avatar
Drives: Tahoe LTZ,2010 2SS/M6 Camaro
Send a message via AIM to ddunerider
I need some!
WE RACE DEEP!!
BBK Intake, Flowmaster AT cat back Barton shifter,Painted stripes,,Heritage grill,LED DRLs, Smokin Tires!!
ddunerider is offline   Reply With Quote
Old 12-23-2013, 09:28 AM   #26
Apex Motorsports
No.
Old 12-23-2013, 10:49 AM   #27
CamaroLS
CamaroLS's Avatar
Drives: 2014 Blue Ray Met. Camaro 1SS Vert
What does the kit look like and how much?
CamaroLS is offline   Reply With Quote
Old 12-24-2013, 04:19 PM   #28
Apex Motorsports
What we installed on his car was just 2 bulbs and a plug and play harness. Vendors can't post pricing in the tech forums but it is under triple digits.
apex motorsports, drl harness, led drl, lighting
