Old 09-03-2019, 04:58 PM   #15
Boost Creep
Boost Creep's Avatar
Drives: '18 1SS 1LE
Originally Posted by eimarshall View Post
That looks like something is rubbing to me....
I'm not sure how toe would affect that far down the edge of the tire.
I'd pull the wheel off and look for something collecting rubber/cord bits.
Yeah, I'd look for some tire contact somewhere, like the top of the strut under the spring perch.
If it were camber it would be more gradual from outside to inside wear not just right at the edge. If it were toe you'd have feather edging of the tread, not a smooth wear pattern like that.
'18 1SS 1LE Black, PDR
Old 09-03-2019, 05:33 PM   #16
TRZ06
TRZ06's Avatar
Drives: 22' Porsche PDK GT4
OP, you have mods or alterations from stock anywhere up front?
Or maybe it has seen front edge damage and something is bent under there?
There is definitely something else going on here.
Current:
Previous:
09' C6 Z06
08' E90 M3
06' 335i (KW V2 Coilovers)
03' C5 Z06
Old 09-03-2019, 09:33 PM   #17
TrackClub
TrackClub's Avatar
What's your tire size and what is your camber/toe spec from the shop that did the alignment? Any mods beyond stock at all? Looks like something rubbing.
Old 09-03-2019, 09:53 PM   #18
kjchristopher
Drives: 911SC
I’m 2.6* front camber with over 10k miles on PS4S tires, including three track days at Cresson. Even wear, probably 5k miles left in them.
kjchristopher is offline   Reply With Quote
Old 09-03-2019, 10:25 PM   #19
TrackClub
TrackClub's Avatar
Actually, looking at the pic real close, the inside tread seems gone as well. So likely not rubbing. Perhaps excessive toe, and/or excessive understeer in R hand side corners under "very aggressive" cornering, perhaps on very abrasive pavement? Just a guess.
Can you send a pic of the L tire please?
Plus your alignment specs. Also, did the shop check your current alignment to ensure it hasn't moved?
Lastly, what mode is the car in when you "corner very aggressively"?
Old 09-03-2019, 11:19 PM   #20
GTSLOW
Daily Driven 1LE
GTSLOW's Avatar
Drives: 2018 1SS 1LE
That tire has to be rubbing on something.
2018 1SS 1LE
GTSLOW is offline   Reply With Quote
Old 09-04-2019, 12:48 AM   #21
JeromeS13
Drives: 2017 1SS/1LE
Toe is off. Post your alignment sheet.
Old 09-04-2019, 10:05 AM   #22
zx9rmal
zx9rmal's Avatar
Drives: '20 ZL1 M6
That's a good idea. I will check that when they are replaced next week. BUT, the other side is starting to show the same thing, so ???
I went back to Costco, where I bought the tires. They don't do alignment. I will be using a different, specialty shop to do the alignment this time, and I will go back to OEM specs.
Costco was great. They discounted the replacement PS4S's based on the mileage proration. With 11,000 miles on the tires, I'm paying $570 mounted, balanced, including tax.
Thanks for the help guys.
Mal
Ft. Lauderdale, FL
'20 Camaro ZL1 M6
'22 Kawasaki ZX-14R
zx9rmal is offline   Reply With Quote
Old 09-04-2019, 10:09 AM   #23
TrackClub
TrackClub's Avatar
Good stuff, but when are you gonna post your alignment specs?
Old 09-04-2019, 02:07 PM   #24
zx9rmal
zx9rmal's Avatar
Drives: '20 ZL1 M6
So here are the alignment results. Done in October, 2018, and again in May, 2019.
Two questions.
1. The toe in October looks ok. The toe in May is off. Can that amount of error kill that front tire in less than 2500 miles.
2. "If" they were not reputable and did shitty job, could they print out a bogus chart from the alignment computer?
Thanks.
Mal
Ft. Lauderdale, FL
'20 Camaro ZL1 M6
'22 Kawasaki ZX-14R
Old 09-04-2019, 02:15 PM   #25
TheRealJA105
TheRealJA105's Avatar
Drives: 2013 C6Z06
Did you put 285/35 tires up front?
Old 09-04-2019, 04:00 PM   #26
zx9rmal
zx9rmal's Avatar
Drives: '20 ZL1 M6
Nope. OEM sizes all around.
Mal
Ft. Lauderdale, FL
'20 Camaro ZL1 M6
'22 Kawasaki ZX-14R
Old 09-04-2019, 04:15 PM   #27
Boost Creep
Drives: '18 1SS 1LE
Two questions.
Thanks.
The alignment in May looks good, better than October. The "before" in May has bad toe out in front, but they fixed that.
Old 09-04-2019, 05:46 PM   #28
TrackClub
TrackClub's Avatar
Both times the specs walked. The before in Oct is horrible. This means the shop didnt tighten things up properly. Assuming it was the same shop and they increaed camber in Oct and specs walked again: not surprised by the results at all. As this would only accelerate inside wear. The question that remains is what are the current specs (to assess any change between Oct and now). Yes 2500 miles is enough to ruin tires, especially if road surfaces are abrasive (high content of gravel in asphalt, or concrete).
