03-24-2019, 02:20 PM | #1 |
Drives: 16 1SS M6 Black -previous 00 Z28 M6 Join Date: Oct 2018
How to disconnect door wiring harness
Anyone know of a thread or can easily explain how to disconnct the wiring harness on the doors? Battery died and after jumping the windows won’t budge. Saw somewhere that disconnecting the harness could help, but honestly(embarrassingly) have no idea what I’m looking at.
Thanks! |
03-24-2019, 02:45 PM | #2 |
OK, I pulled the black hose rubber gasket out and it looks like that’s what I’m trying to get at, but how am I supposed to get my hand in there to disconnect, and more importantly reconnect the harness?
03-24-2019, 02:48 PM | #3 |
Drives: Camaro 50th anniversary edition Join Date: May 2017
Did you check the fuses? The windows are not moving at all? If you open the door the window should lower a bit.
Soleil
_____________________________________________ A car is fast enough, if you fear to unlock it in the morning." (Walter Roehrl) |
03-24-2019, 02:50 PM | #4 |
03-24-2019, 03:39 PM | #5 |
I would try the following.
1. try to open/close the windows with the key fob. 2. Disconnect the negative pol from the battery for 5min. Reconnect and try again. 3. 4.
Soleil
03-24-2019, 04:40 PM | #6 |
Long hauler
Maybe it's the motor itself, my car had windows but wouldn't move at all. Turns out the motor for it was dead, replaced motor and has worked ever since
03-24-2019, 04:55 PM | #7 |
I hope that’s not it, but it could be. Since it’s both I’m hoping it’s a random glitch, but I have an apt to drop it off on Wednesday at the dealer in case I haven’t solved it by then.
03-25-2019, 12:25 PM | #8 |
Unfortunately still persists - bringing it in Wednesday morning for them to look at it. I'll update with whatever the solution is when I find out!
