Old 08-14-2018, 10:37 PM   #1
VJChevelle67
The Beast
VJChevelle67's Avatar
Drives: 2016 2SS Camaro Convertible
Service update
Hi there convertible owners anyone hear of or know of a service update about the rear compartment floor panel , a dislocated grommet not letting the top to Be lowered service # 17209 this is for Some 2016 / 2017 Camaro Converibles ref # 172093090 release date June 2017 I just heard about it while inquireing about a oil change and the new oil spec for the SS still looking into that . Today's date Aug 14/18. Would like to hear what info anyone has on this matter Thanks. Drive like you own it.
VJChevelle67 is offline   Reply With Quote
Old 08-15-2018, 06:04 AM   #2
goshawk823
goshawk823's Avatar
Drives: 2017 RS convertible
they will replace the whole divider. takes about 2 minutes, including signing the paperwork.
Camaros I've owned:
1969 RS/SS Z10 Indy Pace Car - Hardtop 1 of 250
1970 Camaro
2010 2LT RS
2013 2SS RS
Current ride:
2017 Camaro 2LT RS convertible
goshawk823 is offline   Reply With Quote
Old 08-15-2018, 10:32 AM   #3
aland12345
aland12345's Avatar
Drives: 2016 Bright Yellow Camaro vert
I would pass on the fix. the new and "IMPROVED" part fits very loosely at the top any suitcase or duffel in back of trunk bumps it, It will fall down and you have to open trunk and reattach it to allow top to lower. Never had that issue with the original divider...
aland12345 is offline   Reply With Quote
Old 08-15-2018, 01:40 PM   #4
Mark114
Mark114's Avatar
Drives: 2016 2SS Convertible
+1
Unless you're experiencing a problem with your divider keep it and refuse the recall (you can choose). The new divider doesn't work as well as the original. They swapped mine when I had it in for an oil change without telling me until it was already done. If I had known how bad the new one was I would have demanded getting the original divider back.
Old 08-15-2018, 04:08 PM   #5
RickErnst
Rick's6inNJ
RickErnst's Avatar
Drives: 2017 Vert 2LT RS V6
Mine was done when they prepped the car for me back in September. I have noticed a few times where the divider fell down, especially when something heavy is in back of it.
Although I have not tried yet, I'm wondering if a small rubber band (something like they use for braces) wrapped around the knob that holds up the divider would help. Maybe give the divider something to hold on to.
RickErnst is offline   Reply With Quote
Old 08-18-2018, 12:18 AM   #6
VJChevelle67
The Beast
Devider
Thanks for your input I will look into it even more
Old 08-21-2018, 04:35 PM   #7
john94si
john94si's Avatar
Drives: 17 2ss vert
I took mine in for trans shudder and they replaced mine.. I asked if i could have the old one they said no. And yes it does not stay attached near as well as the original. It easy falls down. But i was having issues lowering the top sometimes.
john94si is offline   Reply With Quote
Old 08-30-2018, 12:28 PM   #8
67l78conv
Drives: 1967 RS/SS L78 Very, 2016 2SS Vert
Took mine in for the trans shudder as well. Did not do this until I went to pick it up from the dealer so wondering if they replaced it on mine without telling me. So while still there had them look into the divider falling off due to the grommets not holding tight.
They replaced the grommets and the new ones do not hold the divider close enough for the magnet to engage. As a result I still cannot move the top up or down unless I position it just right. As soon as I drive ti slips out of position again. Dealer was shaking there heads at the issue as well wondering why they did it that way to begin with.
Will be looking into bypassing the sensor when I get back from traveling this weekend.
67l78conv is offline   Reply With Quote
Old 10-21-2018, 08:31 PM   #9
wildchevy
wildchevy's Avatar
Drives: 2018 Hyper Blue 2SS convertible
Why would the replacement parts fall down and the new ones on the 18's don't fall down? You would think the 18's would have the same part as the replacement parts put on 17's
2018 HBM 2SS CONVERTIBLE A8
wildchevy is offline   Reply With Quote
