06-22-2022, 10:29 AM | #1 |
Drives: 2016 2SS White w/blk whls, MRC, 6sp Join Date: Mar 2017
Do Corvette wheels fit?
I have a 2016 2SS and desire a summer set of wheels and tires, keeping the stock for winter with AS tires. I am wondering if Corvette wheels fit. For example, a Z06 staggered set has these dimensions:
Front 285/35/19 Rear 335/35/20 I do not know the offsets. The rears seem too wide, maybe the fronts too? Do other Corvette models (eg, non-Z06) fit? Any problem going with a 19" up front? I appreciate your tutelage on the matter. |
06-22-2022, 10:40 AM | #2 |
Drives: 2018 Audi TT RS Join Date: Jan 2014
I'd be shocked if they did. I believe the offsets don't work for Camaro's.
2018 Audi TT ▊RS
2.4X 0-60, 1.6X 60', 120+mph 1/8th, 4.XX 60-130, 150+mph traps on 255/35/18 R888R tires on the street (unprepped). 2019 Audi RS3 About as fast as the TT RS 2019 Camaro ZL1 1LE Sold 2018 Camaro SS 1LE Sold 2019 Corvette Z06 Sold 2021 Charger Hellcat Redeye Widebody Sold |
06-22-2022, 10:53 AM | #3 |
Drives: 2017 Blue Camaro 1SS 1LE with PDR Join Date: Sep 2018
Also C7 Corvettes have a 5x120.65mm bolt pattern and 70.3mm center bore vs. the Camaro's 5x120mm and 66.9mm. I have heard of people using Corvette rears on the Camaro for drag racing but I would not recommend it due to the slightly different bolt pattern.
06-22-2022, 01:00 PM | #4 |
Drives: 2017 Camaro SS, 2011 Corvette GS Join Date: Feb 2019
I have a 2011 C6 Corvette and a 2017 Camaro SS. Wheels do not fit, different bolt patterns.
06-22-2022, 01:09 PM | #5 |
Drives: 2019 zl1 6 speed Join Date: Jul 2017
Didn't the c6 zo6 rims work?
06-22-2022, 04:54 PM | #6 |
A seller of used Z06 wheels thought they fit the Camaros. "Trust but verify."
Actually, that phrase makes no sense. If you "verify" that means you don't trust. If you "trust" then why verify? I suppose it is just a nice way of saying "I don't trust you". |
06-22-2022, 06:57 PM | #7 |
Drives: 2016 Camaro 2SS Hyper Blue Metallic Join Date: May 2020
Ok, I have to ask. If you are going to keep a set of tires for winter why wouldn't you get dedicated wheels/tires for winter like Blizark? Seems strange to me to get dedicated summer tires and then use the all season tires for winter. Isn't that the purpse of all season is to use them all year? Not meaning any disrespect at all. Just was curious.
I would get dedicated winter tires and then just wrap your wheels with summer only tires. But... that's just me. |
06-22-2022, 07:33 PM | #8 | |
The AS do well enough in the Fall, Winter, and Spring seasons here in Central Indiana. I am sure Blizarks would do even better. The Cooper G1's actually handle quite well for being AS, so they are a good bridge in the Spring and Fall when we might get a bit of snow, and a lot of rain. My 2SS is my daily driver that I use all year long. I am looking for a wider set of wheels and tires for the summertime. Also, I have black OEM wheels on my white 2SS, so I am looking for another look for the other times of the year, like dark bronze. So perhaps not the most practical solution, but takes care of a perceived need... |
06-23-2022, 05:48 AM | #9 | |
I like the MRR 1LE Replica wheels for my car, but I do want to stick with my AS tires. |
06-23-2022, 08:42 AM | #10 |
Drives: Chevrolet SS 1LE Join Date: Oct 2019
C1-C7 wheels are the wrong bolt pattern, as already mentioned: they are all 4-3/4" (120.65mm) vs the 5x120mm that our cars use. So they are a no-go. The C8 uses 5x120, so the bolt pattern works and the hub bore is the same as our Camaros. However, they use a lot more offset, especially in front, so you're going to need big spacers to make them work.
Matt Miller
2020 SS 1LE |
06-23-2022, 10:57 AM | #11 |
I'll stick with the Camaro 1LE wheel dimensions. Thanks for the feedback, folks!
Tags |
corvette wheels |
Thread Tools | |
