06-17-2022, 08:47 AM | #1 |
Drives: Chevy Camaro 1LE Join Date: Mar 2022
MSD Manifold
Anyone fitted the factory foam insulator under the MSD manifold?
06-17-2022, 12:24 PM | #2 |
Drives: 2017 1SS 6spd Join Date: Jan 2011
I think you'll find this was a 50-50 decision on most owner's cars. I went without my foam- it just felt like the MSD seated better without it and I wasn't concerned about any mechanical noise suppression. It's been on the car for 4yrs. now. I've re-torqued the bolts once. All is well.
If anything, it allowed for a channel of cooler air to pass under the IM in my mind. Folks have used the opportunity to apply stick-on heat shielding to the bottom of the IM at this time. But people have done it both ways without adverse effect I believe. I should add that you should follow the install directions implicitly- no dork wrench, invest in a good INCH/lb torque wrench and make at least 3 passes with blue loktite, etc... as instructed. Last edited by Ventmaster; 06-17-2022 at 12:49 PM. |
06-17-2022, 01:46 PM | #3 |
I just installed Lt2 and took it out. I did an MSD on my C7 last year and took that one out also. Not really needed.
06-18-2022, 02:24 AM | #4 |
Drives: like an old lady Join Date: Jun 2012
i felt like the msd has enough trouble with vacuum leaks on its own without introducing another liability. i left it off.
06-19-2022, 06:00 AM | #5 |
thanks for the replies
Thread Tools | |
