Old 06-10-2022, 09:29 PM   #1
NickR1LE
Drives: Camaro 1SS 1LE
Winter Set up
Just picked up a 2020 1SS 1LE a few weeks ago. I know its a bit away but just looking to see what wheels/tires people use or suggest for winter that will clear the breaks on the 1LE(don't worry, the car wont see snow just cold days)
NickR1LE is offline   Reply With Quote
Old 06-11-2022, 05:11 AM   #2
Msquared
Msquared's Avatar
Drives: Chevrolet SS 1LE
I just use stock base 18x8.5 wheels with 245/50/18 tires.
Matt Miller
2020 SS 1LE
Msquared is offline   Reply With Quote
Old 06-11-2022, 09:04 PM   #3
Boost Creep
Boost Creep's Avatar
Drives: '18 1SS 1LE
I picked up a set of ZL1 wheels I plan on running stock 285/305 size Continental DWS's....some day.
Stock SS wheels clear the 1LE brakes.
'18 1SS 1LE Black, PDR
Old 06-11-2022, 09:36 PM   #4
JamesNoBrakes
JamesNoBrakes's Avatar
Drives: 2SS 1LE
19s with studded 255s, I'd have to go back to look at the offset, but it works out real nice where the outside edge is about the same as with my OEM wheels.
2018 2SS 1LE
2023 Colorado ZR2
2022 Stinger GT-line AWD
JamesNoBrakes is offline   Reply With Quote
Old 06-13-2022, 08:47 PM   #5
synolimit
Drives: 22 ZL1 1LE A10
just get a cheap second set and any tire thats a true ice/snow tire. dont go crazy wide, thinners better. if you youtube tire racks comparisons of summer, all season, winter your mind will be made up! stopping shorter by say 20-30 feet might not seem like a lot but have you seen what a 15-20mph car does when it hits something?? it looks terrible! thats the speed difference when a snow tires comes to a stop and the AS keeps going till it stops! with an ice and snow tire you'll be able to out drive anything on the road no matter the drive train or what it is! remember, snow driving isnt about insane acceleration, its about turning and stopping.
synolimit is offline   Reply With Quote
Old 06-15-2022, 08:10 AM   #6
SFHess
Drives: 2016 Mystic Green Chevrolet SS
I have a set of these that I used on my 2020 SS 1LE. The only issue I had was when turning sharply (like in a parking lot or whatnot) the inside diameter of the wheel rubs on the air deflectors. Other than that they clear the front calipers by a couple of hairs widths.
Just looks a little odd to see it on those wheels.
SFHess is offline   Reply With Quote
Old 06-15-2022, 11:46 AM   #7
Msquared
Msquared's Avatar
Yep, I trimmed one small corner of the deflectors and use 5mm spacers (which I already had on hand for use with other wheels) and that was enough to clear those deflectors.
Matt Miller
2020 SS 1LE
Old 06-15-2022, 12:25 PM   #8
DaveC113
DaveC113's Avatar
Drives: 2018 Camaro 1SS 1LE
You can get a set of 19x10 27mm offset to have the same outside position as OEM using a 7mm spacer up front and 1/2" longer wheels studs, which are very easy to install. Or you can use a 5mm spacer with OEM studs, won't make a big difference, but I needed longer front studs anyways. I got a set of MRR wheels on a 40% off sale via discount tire.
I run 265/40/19 Michelin Pilot Alpin tires.
https://www.tirerack.com/tires/tires...A5XL&tab=Sizes
Wheel offset calculators make things much easier:
https://www.1010tires.com/Tools/Whee...et-Calculator#
Old 06-15-2022, 12:34 PM   #9
SATINSTEEL1LE
Drives: 21 ZL1
I run drag radials.
Oh wait I live in Florida...LOL Man I love being able to do that on car forums. I waited 39 years to be able to...ahahaha
SATINSTEEL1LE is offline   Reply With Quote
Old 06-15-2022, 01:06 PM   #10
WhiteMale
Drives: 23 ZL1 A10 Rapid Blue
Mich Alpin PA4 on the 1LE wheels but I run 275/35 and 285/35 on that wheel.
I needed more winter tire than an A/S.
Old 06-20-2022, 02:37 PM   #11
BrandanK
Drives: 2021 Camaro SS 1LE
I also picked up a set of stock 20" x 8.5" Camaro wheels. I put Continental DWS 06 all season tires on them (245/40/20).
BrandanK is offline   Reply With Quote
