Old 04-08-2021, 09:16 AM   #1
tecboy
tecboy's Avatar
NPP vs Borla AxleBack S-Type Sound
Have a 2016 SS V8 with NPP...looking at possibly doing a Borla Axleback S type NPP system. Anyone that has made this same change, how much did overall sound level increase? Was there a noticeable difference in tone? Looking for a little louder and deeper tone than the stock NPP system has...
2016 Black 2SS A8 NPP Sunroof - Tinted Windows - Black Chrome Wheels - Custom Striping - ASC Sideskirts/Splitter - GM Lowering Kit - Complete Sound System - DD LED Sidemarkers
tecboy is offline   Reply With Quote
Old 04-08-2021, 09:39 AM   #2
Staves
Drives: women crazy
I test drove NPP SSs before I got my SS with non NPP and now have non NPP Borla type-S.
I think the sound of mine will sound the same as NPP version just valves are always open.
I think the type S sounds amazing and better than the NPP from the factory. But it’s not a ton louder, maybe slightly. If I already had NPP, I doubt you’ll notice much of a difference.
‘19 1SS A10, Borla S-type Non-NPP-SOLD
Staves is offline   Reply With Quote
Old 04-08-2021, 10:04 AM   #3
Spaceme1117
Spaceme1117's Avatar
Drives: 2017 Camaro SS, 2011 Corvette GS
Thinking a little differently here but I have noticed a definite difference in the sound of the stock NPP on my 2017 SS after I installed a Roto-Fab intake. It is the Roto-Fab version that deletes the sound tube and has the dry filter.
I can definitely notice that over all the exhaust is slightly louder in Tour, louder still in Sport, and a good bit louder in Track.
Definitely, a more noticeable difference between the modes.
Spaceme1117 is offline   Reply With Quote
Old 04-08-2021, 10:28 AM   #4
Crushin_LT1
Crushin_LT1's Avatar
Drives: 2021 LT1 6spd
I did the GMPP CAI/Cold Air Industries CAI - it definitely made both intake and exhaust slightly louder and slightly deeper. I did NOT have a soundtube from the factory, I do have NPP.
Current: 2021 LT1 Camaro, 6spd, Crush, Corsa NPP, GMPP CAI, Soler Performance Throttle controller
Previous: 1997 V6 Camaro, 5spd, Black
Crushin_LT1 is offline   Reply With Quote
Old 04-08-2021, 10:30 AM   #5
Crushin_LT1
OP, check some fo the videos out on Youtube through either your sound system or good headphones. S-Type is supposed to be deeper and slightly louder.
I'm installing the Corsa NPP system on mine in about 2 weeks, it's deeper (not as deep as S-Type) but louder than NPP and S-Type.
Old 04-08-2021, 11:05 AM   #6
tecboy
tecboy's Avatar
I have listened to the Borla video with sound comparisons...even with good headphones, a recording of exhaust sound vs real life will def be different..99% of the time the NPP valves are open (running in track mode) but still would like the ability to close if i ever wanted to be quieter....
Old 04-08-2021, 11:15 AM   #7
Crushin_LT1
It is hard to tell in a video, microphones just can't pick up the depth and range.
You're in cincy, you might be able to hear your desired at a cars/coffee or camaro meetup or even heading to Borla's shop in TN or a local exhaust shop.
Old 04-08-2021, 11:20 AM   #8
ST1LE
ST1LE's Avatar
Drives: E92 BMW M3
Sounds like the Borla S Axleback will be perfect. A little louder, certainly deeper, and also cleaner and less raspy.
To me it is V8 perfection.
J-Rod Built and Matt@FSP Tuned
ST1LE is offline   Reply With Quote
Old 04-08-2021, 12:20 PM   #9
ssmike
BL1ZZRD
ssmike's Avatar
Drives: '16 Camaro 2SS, '20 Equinox Redline
I had the stock NPP and went with S-Type mufflers without the valves. I can honestly say that the tone is deeper, especially at idle, and it’s definitely louder than NPP with valves open. It’s perfect IMO! Also, the RotoFab does increase the sound level a little. I definitely notice the difference.
ssmike is offline   Reply With Quote
Old 04-08-2021, 12:50 PM   #10
z28pat
z28pat's Avatar
Drives: 2002 z28, 2018 2ss 1LE
I just made the switch to the borla s type , it’s a little louder, but mostly deeper.
https://imgur.com/a/02jE2dk
z28pat is offline   Reply With Quote
Old 05-29-2021, 01:32 PM   #11
GermanA
GermanA's Avatar
Drives: 2018 Camaro 2SS 1LE
I just installed the borla S type axle back npp and have video of pre install and post. I will attempt to post the videos. It is much louder, not obnoxious, and deeper. If you are wanting a better sound while retaining the npp function, I highly recommend it. This is installed and the link above is factory.
https://youtu.be/dEhj40_88xc
GermanA is offline   Reply With Quote
Old 05-29-2021, 01:39 PM   #12
AZIROC
Drives: '86 IROC-Z '18 ZL1
Imo, the borla S type has the "classic" borla deep tone to it. It is alittle louder than stock, but for me, its the deeper tone it has as im not looking for something loud.
Old 05-29-2021, 03:27 PM   #13
Motor Fast
Drives: 2018 Camaro SS 1LE
If you're looking for a little louder check out the Hendrick Hertz SS video in my signature below. They come with the GM Performance exhaust. It's a little louder and the tone is cleaned up on engine breaking. It's sounds better than what comes through in the video.
2002 Camaro SS | 2003 Corvette Z06 | 2008 Corvette| 2016 Corvette Z06 C7.R | 2018 Camaro SS 1LE
Motor Fast is offline   Reply With Quote
Old 05-29-2021, 03:30 PM   #14
Motor Fast
Startup has a really good sound.
