09-25-2023, 02:06 PM | #15 |
Drives: 2017 Chevrolet Camaro ZL1 Join Date: Jul 2018
It is definitely a drag strip only setup, but I do have a filter if I want to drive it on the street. Haven’t seen any indication that it has inhaled any flying creatures yet. Lol
2017 ZL1 - PB 8.05 @ 172 MPH @ 3730 lbs @ 70 DA (work in progress)
Built by Vengeance Racing, tuned by Elite Tuned |
09-25-2023, 02:20 PM | #16 |
Which filter?
'20 ZL1 1LE A10,
09-25-2023, 02:27 PM | #17 |
Just a regular green filter that goes in place of the bellmouth. I don’t recall the brand. It was actually on when the car ran the 8.20.
09-25-2023, 02:45 PM | #18 |
You mention density altitude of 3300 ft, how much ET improvement do you think your car would see if it was at zero feet rather than 3300 ft
'20 ZL1 1LE A10,
09-25-2023, 02:55 PM | #19 |
Well the 8.20 @ 173 PB was ran in a little over 1k DA. The same setup was at an event a couple weeks prior with ~3300 DA and it ran 8.38 at 170. The 8.20 was literally off the trailer with no ice because it was a shake down pass, but then had an issue that required stopping for the day. Between having the filter off, putting different pulley’s on, and a couple other things, it should run 8.0x - 8.1x even in 3k DA. We just keep finding the next weak part or part getting tired.
09-25-2023, 03:00 PM | #20 | |
Drives: 2023 Camaro ZL1 Join Date: Jul 2023
It’s all about mass airflow… Pressure & Temperature. The important part is ensuring the air can get in the supercharger. i.e. how close to atmospheric pressure and temperature is the inlet of the supercharger. Then you look at the volumetric efficiency of the supercharger, supercharger speed, supercharger displacement and air density.. this will tell the mass airflow into the engine. These are the only variables that will affect airflow into the engine Once the air is in the supercharger, it will go in the engine. intercooler or not. Then the intercooler is there to do two things, reduce the pressure and have the air cool enough to not cause suboptimal spark timing. At a high level, it won’t increase your airflow (unless you end up at a better part of the volumetric efficiency map due to lower pressure) It is really quite easy to build an excel table that will allow you to calculate how much impact the inlet restrictions or hot IAT will have. |
09-25-2023, 03:40 PM | #21 | |
'20 ZL1 1LE A10,
09-25-2023, 04:07 PM | #22 | |
09-25-2023, 04:10 PM | #23 | |
Drives: 2021 Red Hot ZL1 Join Date: Sep 2020
09-25-2023, 05:53 PM | #24 |
That's .18 over 2300 ft., so that setup should run 8.10-8.11 at 0 ft. Using your .18 improvements over 2300 ft., my 9.61 would improve .54 theoretically, to 9.07, while I've been thinking 9.15. I've still got a ways to go to 8.9x. There's still more Jenny Craig I could do.
'20 ZL1 1LE A10,
09-26-2023, 12:03 PM | #25 | |
That new intake I referenced, while enabling more air into the blower, it also started forcing my TB closed. It already has the latest upgraded motor in it so Nick Williams sent us some new stuff try.
09-26-2023, 12:06 PM | #26 | |
'20 ZL1 1LE A10,
09-26-2023, 12:16 PM | #27 |
The new intake did need a new tune. The one in the picture was able to run with filter on or off with the current engine. My old engine needed a separate tune for filter and velocity stack. Part of the challenge there is the 120mm TB.
09-26-2023, 01:05 PM | #28 |
I can imagine. Just getting from the 6-in big gulp to the 4.4 in throttle body on my engine wasn't easy
'20 ZL1 1LE A10,
