08-07-2023, 05:32 PM | #15 | |
'20 ZL1 1LE A10,
08-08-2023, 08:17 AM | #16 |
Exactly. If you want the 2-3 to shift at say 6700 rpms and 6700 rpms is 65 mph. I'd set the shift mph at 61 mph and test it. See where that puts you. These are A8 settings, your A10 2-3 will be lower.
08-09-2023, 12:25 PM | #17 |
KingLT1 saw this thread and has solved my problem. Mph is the controlling criterion.
'20 ZL1 1LE A10,
OEM short block, LME heads/valve train, E2650. 100+ octanes, no eth, no meth, no N2O. 2/23 - 1031/1004 wheel. 4/23 - 1.41/9.61/145 at DA 7000 ft. (only made five passes). 2/24 - LME 390, E2650, FBO, 100 oct.; 1116hp/ 1063tq; 109 oct. dyno next. Last edited by JSH; 08-09-2023 at 12:46 PM. |
08-09-2023, 05:29 PM | #18 |
You're in good hands.
08-11-2023, 09:27 AM | #19 |
Petro-sexual
Did you ever get the 2nd Gear start figured out?
I checked, again, yesterday, but - at least with a T87A conversion, it is not possible to shift into 2nd Gear when the car is stopped. I have to roll to a stop, already in TUTD 2nd-Gear, in order to force a start in 2nd-Gear... This is still on the T87A converstion - I am not on a tuned T93.
08-11-2023, 10:45 AM | #20 | |
'20 ZL1 1LE A10,
08-11-2023, 11:34 AM | #21 | |
Petro-sexual
Sorry about my confusing wording...
08-11-2023, 05:35 PM | #22 |
1st gear is deleted, so it moves forward in second gear from stop.
'20 ZL1 1LE A10,
OEM short block, LME heads/valve train, E2650. 100+ octanes, no eth, no meth, no N2O. 2/23 - 1031/1004 wheel. 4/23 - 1.41/9.61/145 at DA 7000 ft. (only made five passes). 2/24 - LME 390, E2650, FBO, 100 oct.; 1116hp/ 1063tq; 109 oct. dyno next. Last edited by JSH; 08-12-2023 at 08:26 AM. |
08-11-2023, 09:33 PM | #23 |
The transmission never downshifts to 1st.... It stays in 2nd gear.
2016 NFG 1SS A8
08-12-2023, 10:29 AM | #24 | |
I’ve played with the trans settings for years and somehow never even tried to mess with that, even though 1-2 sucks.
08-12-2023, 11:28 AM | #25 |
Petro-sexual
Yes. But I THOUGT (I could likely be misunderstanding) people are reporting they can shift INTO 2nd from a stop. Can you do that, or is everyone saying they have to roll to a stop, in 2nd already, then they can make the run from 2nd?… Maybe I’m just not saying it right…
08-12-2023, 11:35 AM | #26 | |
Drives: Chevy Camaro Join Date: Sep 2022
'20 Camaro LT1
Twin 67/62 turbo 401(L8t) Texas speed forged piston & rod, BTR stg1 turbo cam, holley ultra lo, port injection, circle d 3600 stall, hoosier bias ply quick time pro's on racestar recluse wheels 1.45 4.01 6.07@120.74 9.28@153.43 '94 Camaro Z28 6mt cc306 cam, 4:10's, longtubes with x pipe, getting an engine rebuild |
08-12-2023, 01:13 PM | #27 | |
08-12-2023, 02:20 PM | #28 |
Same here, and I don't think it's in the tune, I didn't see any TCM change that appears be related. At the drag strip I switch to competitive mode, do a burnout in manual trans mode, then once stopped, I shift to 2nd, launch and slap the stick over to auto.
