08-05-2023, 12:12 PM | #1 |
A10 87A TCM 1st gear delete in Auto
Has anyone done an A10 87A TCM 1st gear delete in Auto? Mine is deleted in Manual only. I'll also ask on HPT board.
'20 ZL1 1LE A10,
08-05-2023, 01:00 PM | #2 |
Drives: Chevy Camaro Join Date: Sep 2022
I’ll look at my tune to see how it would be possible. Can I ask why or what you are trying to achieve?
'20 Camaro LT1
Twin 67/62 turbo 401(L8t) Texas speed forged piston & rod, BTR stg1 turbo cam, holley ultra lo, port injection, circle d 3600 stall, hoosier bias ply quick time pro's on racestar recluse wheels 1.45 4.01 6.07@120.74 9.28@153.43 '94 Camaro Z28 6mt cc306 cam, 4:10's, longtubes with x pipe, getting an engine rebuild |
08-05-2023, 01:43 PM | #3 | |
On the other hand, in auto mode, the TCM is tuned to shift at my commanded levels 63-6500, but I don't have first gear delete. My peak horsepower is in the 6200/6300 range, so I want the car to make the shifts at 6400/ 6500 peak. This will also reduce the blower max rpm by 2,000 and reduce heat. HPE's 850 version was a high-rpm hp motor, but this one's not.
'20 ZL1 1LE A10,
OEM short block, LME heads/valve train, E2650. 100+ octanes, no eth, no meth, no N2O. 2/23 - 1031/1004 wheel. 4/23 - 1.41/9.61/145 at DA 7000 ft. (only made five passes). 2/24 - LME 390, E2650, FBO, 100 oct.; 1116hp/ 1063tq; 109 oct. dyno next. Last edited by JSH; 08-05-2023 at 03:34 PM. |
08-05-2023, 01:51 PM | #4 |
If you raise all your speed shift points beyond and just change the shift rpm in tutd it should referrence that. Granted mine doesn’t make that till 3rd & 4th right now. In theory it should work but I will look and see what could get what you want
Edit why not just copy your shift speeds from auto to tutd? Are you doing this tuning or communicating it to a tuner?
'20 Camaro LT1
08-05-2023, 02:35 PM | #5 | |
'20 ZL1 1LE A10,
08-05-2023, 06:26 PM | #6 |
In a nutshell, this is what i think you need to do. The only reason TUTD doesnt upshift stock is that is set to shift way above the redline/cutoff.
Then you just put it in manual mode and push the stick forward to start in second, then it'll upshift normally without moving the stick.
08-05-2023, 06:34 PM | #7 | |
08-05-2023, 08:08 PM | #8 | ||
When I then pull the shift lever to the left into manual, it can't see 1st gear and is in 2nd gear. It will shift automatically at wot. This how I made my five passes, but it shifts at 7000 rather than the 6500 I need. So another question is, can the T87A be programmed to shift at 6500 in manual. This one has never done that. This is the function I need.
'20 ZL1 1LE A10,
08-07-2023, 07:11 AM | #9 |
Petro-sexual
I thought I read our trannys (original T93-cars) have to be in 2nd when rolling into pre-stage/staging. I know my T87A won't shift into 2nd from a stop, even with the prescribed changes to the TCM...
08-07-2023, 07:12 AM | #10 |
Petro-sexual
I wonder if the T93-flashes can do it.
08-07-2023, 07:50 AM | #11 | |
All I really need is a way to get my T87a to shift consistently at say 6500, whereas it now shifts at 6900-7000, at the strip. Otherwise, I'll shift it manually.
'20 ZL1 1LE A10,
08-07-2023, 08:23 AM | #12 | |
Petro-sexual
Are you having this problem in any gear, or in a specific one? I'm probably already stating something you already know, but on the lower gears, especially with as much power as you're making, I've read it is sometimes necessary to lower the shift speed because the TCM/tranny needs to start the shift process sooner. This was more of an issue in the 1-2 shift, if I recall (maybe even 2-3, in a case like yours, because of your build). Could it, also, be a possibility your tranny is just not up to this task, at this power level? Are you commanding enough pressure? I thought these were only reliable until up to about where you are...
08-07-2023, 08:46 AM | #13 | |
My trans has no other issues.
'20 ZL1 1LE A10,
OEM short block, LME heads/valve train, E2650. 100+ octanes, no eth, no meth, no N2O. 2/23 - 1031/1004 wheel. 4/23 - 1.41/9.61/145 at DA 7000 ft. (only made five passes). 2/24 - LME 390, E2650, FBO, 100 oct.; 1116hp/ 1063tq; 109 oct. dyno next. Last edited by JSH; 08-07-2023 at 11:48 AM. |
08-07-2023, 08:57 AM | #14 |
Attachment 1133218These should be the tables you need to edit. I downloaded a stock 2017 Zl1 file from hptuners. the tables look like the A8...so, in theory these tables should be the ones you need to modify. I can tell these are way way too high a mph to shift at 6500. You'll hit the limiter with these stock settings.
New Mods - GPI drop ins, Kooks 2", LT4 fueling, Cam, Circle D Converter, 3.5 pulley & dual nozzle meth. Last edited by grampa_ss; 08-07-2023 at 09:38 AM. |
