02-20-2022, 10:57 AM | #15 |
Drives: 18 ZLE, 18 SS1LE, 16 SS, 23 ZL1 Join Date: Jan 2021
Sounds plausible, but wouldn’t fit there. I finally broke down and took apart the trunk on my 2021 SS 1LE and there is no foam around the battery.
02-20-2022, 01:12 PM | #16 | |
Drives: 2011 2SS/RS LS3 Join Date: Nov 2011
P.S. I guess no 20 dollars for me...lol |
02-20-2022, 01:17 PM | #17 |
Drives: 2019 ZL-1 Join Date: Feb 2009
That part is made with expandable foam and is meant for absorbing energy. So it is either for doors, interior panels etc. Its is not for sound deadening, the dynamat style products are much better for that. It may also be meant for filling a space to keep a styling shape under carpet etc on a vertical surface.
2012 Yukon XL Denali w/ 6.2 AWD |
02-20-2022, 05:43 PM | #18 |
I found a clue but not any closer to an answer. I had my center console out and noticed the little butterfly tabs that secure through the carpet
02-20-2022, 06:34 PM | #19 |
Drives: 2016 2SS Convertible Join Date: Dec 2019
I was going to guess under that rear compartment under the wireless charger pad of the console, but I'm guessing you tried it in there and it doesn't fit.
GM parts diagrams are scattered with references to "sound absorbers" that do not show exact shapes, so that's why I said "sound deadener" earlier. GM does not use "Dynamat" that I've seen. They use these foam fillers in many places, as well as "jute". Jute is the thick padding stuff under the carpets. I know because I had an Equinox that got some water at the floor level when an airport parking lot flooded some years ago where my car was parked. It barely got up to the door sills, but apparently enough to leak and soak the F&R floor area. The fix determined by the dealer/insurance was to replace the "jute" and clean the carpets.
Hyper Blue/Ash Gray A8 Magnetic Ride Control Dual Mode Exhaust 2019+ version Split Spoke Silver Wheels Navigation Silver Rally Stripes |
02-20-2022, 07:32 PM | #20 |
Drives: 2022 1SS 1LE A10 BCD WCT+PDR Join Date: Mar 2008
Possibly at the front passenger floor closer to the firewall. Near where the passenger would place there feet. If the car has PDR this piece would not be there. It would replace the PDR module and mount on cars without PDR.
02-20-2022, 07:52 PM | #21 | |
02-21-2022, 11:22 AM | #22 | |
@zle_blackwing
Drives: 2018 ZL1 1LE Join Date: Mar 2017
I love a good story with a happy ending.
02-21-2022, 12:22 PM | #23 | |
Drives: 2020 Cadillac XT4, 2022 LT1 Join Date: Jan 2022
02-21-2022, 01:59 PM | #24 |
Drives: 2017 Camaro SS, 2011 Corvette GS Join Date: Feb 2019
