TireRack
Old 02-22-2021, 07:54 AM   #1
rober
Drives: 2015 camaro
Manual transmission fluid change
Hi all,
I'm planning to change the transmission fluid on my v6 2015 camaro. The manual says that the gear fluid should be 75W-90 GL-5. I saw some gear oil brands at Walmart, namely, Ultra1Plus SAE 75W-90 Synthetic Gear Oil, API GL-5, and Valvoline High Performance SAE 75W-90 Gear Oil. Have you used these tran fluid before?
Thanks!
rober is offline   Reply With Quote
Old 02-22-2021, 07:58 AM   #2
ChibiBlackSheep
ChibiBlackSheep's Avatar
Drives: 2012 2SS/RS, 1968 SS
You'll be fine with either of them, gear oil is pretty uniform.
I personally used Mobil 1 in both the trans and the differential. I recommend doing both at the same time since its easy and it uses the same fluids. Just make sure you grab a bottle of diff lubricant too
LS3 Crate Engine Swap | CSP Custom Cam 232/240 .615/.615 113 +3 | Stainless Power LT Headers | Z28 Intake | Borla S-Type Exhaust | FTI Triple-Disc Billet 3200 Stall
2012 Camaro 2SS/RS | 1968 Camaro SS | 2020 Cadillac CT5 Premium Luxury | 2021 Spark LS
ChibiBlackSheep is offline   Reply With Quote
Old 02-22-2021, 07:37 PM   #3
rober
Drives: 2015 camaro
Manual transmission fluid changed
Hi,
Do you know where the drain plug is? Is it the 24mm plug on the bottom or a 3/8 plug on the passenger side? The filler plug is on the driver side next to the sensor. I heard people said that the drain plug is on the passenger side but I can't find it. Thanks!
Old 02-23-2021, 11:33 AM   #4
ChibiBlackSheep
Check this out: https://www.camaro5.com/forums/album...ctureid=128127
manual tranmission, transmission, transmission fluid
