09-14-2017, 06:24 PM | #1 |
Drives: Summit White 1LT RS I4 M6 Join Date: Oct 2016
M6 Shift lever rattle
Hi,
my 2.0 M6 Gear shift lever rattles in certain RPMs while on 2nd, 4th and 6th gear. It stops rattling when I touch the shift knob. It does not rattle the car is cold and in the morning hours. but when it is hot outside and I drive when the interior is hot, it starts rattling though the car has been parked since morning. I took it to the dealer today and we were able to reproduce the issue. The dealer said that they have to remove the console and see if the problem is with the shifter or console plastic due to heat. Has anybody else faced the same issue? thoughts please Thank you
2016 1LT RS Summit White M6 10/2/2016 - 3 Miles on ODO - Delivered 11/1/2016 - All around light Black out kit from Phastek 11/15/2016 - OEM Splash guards and all weather mats from ShopChevyParts.com 12/16/16 - 977 Miles. Borla S-type Axleback Planned - CAI Injen, hood wrap, Sema rocker stripes, Sema trunk balckout, Caliper Paint, Reverse LED |
09-14-2017, 06:40 PM | #2 | |
SoCal HT5! SD
Drives: 2016 red hot 2ss M6 Join Date: Nov 2011
pull the boot up, and tighten the set screw. Watch this video to see how to get to the set screw:
http://www.camaro5.com/forums/showth...37#post5437037
By my deeds, I honor him. V8!!! |
09-14-2017, 11:27 PM | #3 |
Drives: 2017 1LT RS M6 Join Date: Jun 2017
I had a rattle in my shifter also, that was driving me nuts. I popped the center boot up and removed the shift knob and drove it around and no noise.
Yes it may have been the set screw or the plastic clips that hold the knob to the plastic collor that holds the top of the shift boot. But I changed the knob to a pistol. |
09-15-2017, 10:12 AM | #4 |
Yep mine does the same thing
16 Summit White 2SS M6, everything but keyless entry. Mamo Throttle Body on the way!
09-15-2017, 01:59 PM | #5 |
Drives: '17 1LT RS V6 6M NPP Join Date: Apr 2016
09-16-2017, 12:07 AM | #6 |
did you change the shifter or just the knob.
Is the knob too heavy to pull the shift lever to rattle?
09-16-2017, 12:41 AM | #7 |
SoCal HT5! SD
No, there is a set screw which keeps the knob assembly from turning. It can become loose. The knob does not need to be removed, simply back the loose screw out, apply blue thread locker, and tighten. Buzzing gone.
09-23-2017, 02:00 AM | #8 |
Drives: 2017 2LT- FIFTY EDITION/ M6, V6, RS Join Date: Mar 2017
I recently had the same issue in my car, took it to the dealer and they torqued the screw and no problems ever since.
09-26-2017, 10:57 AM | #9 |
Thank you all for your response.
I tightened the set screw and no issue now.
09-26-2017, 12:37 PM | #10 |
SoCal HT5! SD
Good job OP!
09-26-2017, 12:53 PM | #11 |
Drives: SS-6-SPD Join Date: Jan 2017
as other mentioned above, try tighten the knob screw. put loctite.
02-28-2019, 11:53 PM | #12 |
Drives: '17 2LT/RS 2.0T M6 50th Anniv Vert Join Date: Feb 2019
Re-hashing an old thread! Great forum and wanted to thank everyone for this post...had the same issue on my new leftover '17 and this solution definitely fixed the shifter rattle I had.
03-01-2019, 10:45 PM | #13 |
Mine rattles too on occasion but doesn’t bother me. I had a few Hurst shifters in my Camaros over the years and they all rattled and buzzed while driving. My 2010 Hurst shifter was real noisy but I got so used to it that I ignored it while driving.
03-01-2019, 10:55 PM | #14 |
Drives: 2017 Camaro 1SS M6 Join Date: Apr 2015
In my experience, on the '16+ SS, the stock and Hurst shifters do not rattle at all. Coming from a 4th gen I was surprised by this.
2017 Camaro 1SS, M6, Hurst shifter, Hyper Blue, NPP, Gray Split Spoke Wheels
Best 1/4 Mile: 12.24 @ 115.9 mph |
