04-26-2020, 05:28 PM | #1 |
Drives: 2010 Chervrolet Camaro 2SS M6 Join Date: Apr 2020
Timing Suspension Bushings
New guy here I have my 2SS on jackstands as I am installing Full ARH exhaust and MGW shifter , my question is will i need to have my bushings re-timed when im finished or is that just a must do when doing suspension mods ?
04-26-2020, 05:33 PM | #2 |
Drives: 2011 Camaro 2SS LS3 Whipple Join Date: May 2019
Only if you're changing the ride height or you unbolt a suspension component that has a fixed bushing in it.
Whipple 2.9 CAI ID1050x injectors ZL1 Pump JRE FPCM JMS Voltage booster JRE Rough Idle blower cam BTR .660 springs CHE trunnion kit 1 7/8 Speed Engineering Borla Atak JRE scoop 1.5" lowering springs BMR trailing arms and toe links Cradle inserts 704WHP 603WTQ 93 octane
04-26-2020, 05:42 PM | #3 |
Thanks I appreciate it , Im also going to upgrade my suspension to 1LE track pack and Im not sure how the car will sit with factory springs ? and Im thinking would like to lower the car 1'' as well . Any recommendations what springs and why
04-26-2020, 05:48 PM | #4 |
1" is about as far as you want to go to retain a good ride. I went lower and now i'm looking at coilovers the strut is riding too low and will bottom out too easily. A lot run the bmr 1" lowering springs and like them.
04-26-2020, 05:52 PM | #5 |
Cool Thanks for the heads up , I will check out the BMR springs
04-27-2020, 10:30 AM | #6 |
Drives: 2015 Z/22 Join Date: Aug 2015
I don't have much experience with lowering springs in general but I had Eibach's on mine before the coilovers, and all I can say for the fifth gen is you'll want linear springs the highest spring rates you can find. With the Eibach's I believe they were progressive (different spring rate throughout compression range), or maybe they just have a lower rate, and I was bottoming all the time, way too often. I believe BMR has one of the higher rates out there.
Also as mentioned, a 1" drop is adequate, if you go too low you change the suspension geometry too much and can end up making the handling worse. With my coilovers I'm somewhere around 1 - 1.25" and I don't get much bump steer or anything unusual.
Overkill/Self Tuned; Mace Camshafts; K&N Typhoon Cold Air Intake; Ported 80mm Throttle Body/Intake Manifolds/Manifold Spacer; Solo Performance High-Flow Cats, Cat-back Exhaust; Vitesse Motorsports Throttle Controller; Elite Engineering E2 Catch Can; BC Racing BR Coilovers; JPSS Delrin Radius Rod Bushing Inserts, Sway Bars; Pegasus Aluminum Rear Cradle Bushings, Camber/Caster Plates; Z/28 Toe Links, Trailing Arms, Upper Control Arm Bushings, Rear Shock Mounts
04-27-2020, 08:10 PM | #7 |
Thanks for the good to know info I appreciate it
04-27-2020, 08:13 PM | #8 |
Drives: 2012 Camaro SS Join Date: Dec 2019
Most people go for the bmr 1” or the 1.25” lowering springs. Also bmr makes some really good trailing and toe arms for not that much
2012 Camaro 2SS/RS - CSP Custom Cam 232/240 .615/.615 113 +3, Texas speed CNC heads, FTI billet triple disc converter, K&N cai, Katech ported TB, GPI Ported/rod modded manifold, Texas speed 1 7/8 headers, HFC, Flowmaster 2 chambers with x pipe, Mishimoto CC, MSD wires, Roto fab washer relocation, tru cool 40k trans cooler, apex scoop, Pedders extreme coil overs and much more!!
