10-26-2018, 07:26 AM | #1 |
Drives: ´18 ZL1 A10 Red Hot 😍 Join Date: Jan 2016
Can be run 295 front and 305 rear? Need advice...
Hello,
Well, in EU it´s impossible to buy GY Supercar3 (not EU homologation), so if I want a semi-slick who can be used in wet too must go to Sport Cup 2 or Maxx Race. The question is simple: as 295/30ZR20 is cheaper in both models than 285/30ZR20, do you recommend to use this setup instead 285 in front? Rear will be 305. Another option is to use 305 in front and rear, but not sure about that because front wheel is slimmer than rear one... Thank you!
First ZL1 in Spain (Madrid)! Red Hot, A10, PDR, carbon fiber hood & grounds effects...
10-26-2018, 08:20 AM | #2 |
Drives: SS-6-SPD Join Date: Jan 2017
This regular recommended specs rim width vs tire size.
Rim width 10" (254MM) Tire Size Range - 255MM - 285MM Rim Width 11" (280MM) Tire Size Range - 275MM - 305MM using s 295 upfront will reduce you cut radius, but to answer your question yes they should fit with stock specs. |
10-30-2018, 11:38 AM | #3 | |
More opinions?
10-30-2018, 01:38 PM | #4 |
Drives: 2018 ZL-1 Join Date: Jan 2018
My opinion is to run factory recommended tire sizes. You are running a $65,000 car and are concerned about saving a few Euros on tires by using the wrong sizes?
10-30-2018, 03:41 PM | #5 |
Drives: E46 S54 race car, 964C2 Join Date: Feb 2017
10-30-2018, 05:19 PM | #6 |
Sport Cup 2 or Maxx Race are 500€ per tire. If I was concerned about savings I would buy PS4S or GY Assym3, so stop saying gilipolleces...
10-30-2018, 05:21 PM | #7 |
Thank you!
11-21-2018, 01:10 PM | #8 |
Drives: 2018 Camaro ZL1 Summit White Join Date: Apr 2018
Currently mounted Bridgestone Potenza RE980AS on stock ZL1 wheels.
295/30 front and 305/30 rear. |
11-21-2018, 02:33 PM | #9 |
Tony
Drives: 17 ZL1 Join Date: Nov 2015
How do you like the REs?
-Tony
11-21-2018, 03:36 PM | #10 | |
Drives: 2018 ZL1 coupe Join Date: Nov 2018
In normal driving, they are slightly quieter and ride a little nicer than the stock GYs. I pulled the GY's at 3k miles, so not an "old to new" comparison. Of course, no worries about our freezing temps with the all season 'Stones. I'm going to try to get out for a 'spirited' drive with some friends Saturday morning, so I'll report back after that. I certainly don't expect the level of grip to be on par with the GYs, but it should be plenty for rational street driving. |
11-21-2018, 03:39 PM | #11 |
They are not as grippy as stock GY’s in dry. But honestly daily drivability wise they’re great. Grippy enough in non practical conditions (rain and temps under 50) I can actually give the car a fair amount of gas before the tires break loose.
It was a tossup between these and the BF Goodrich sport comp 2 but tire rack had better reviews for the RE. |
11-21-2018, 04:45 PM | #12 |
Drives: 2018 ZL1 Join Date: Jul 2017
Michelin SS 295/30/20 on front of my ZL1 fit great.
Mark E.
2018 ZL1 NGM A10 87 Grand National. Modified Hot Rod for sale *SOLD* 87 Grand National. Stock 65 Olds Vista Cruiser wagon Grand National motor/tran 66 Bronco Rockbuggy 2006 Dodge 2500 4x4 Cummins 6 speed |
11-21-2018, 05:28 PM | #13 |
Thank you all for your replies!
