02-22-2023, 12:07 PM | #15 |
You may have a slight advantage.
Buy me a forged BE and I'll accept your challenge!
02-22-2023, 01:51 PM | #16 |
With a Whipple 3.0 on the way you might not want to…
03-03-2023, 01:28 PM | #17 |
Drives: 21 Lt1 Join Date: Dec 2016
10.5 @ 135 mph with p1x at 9psi. Sbe, lt4 fueling 614whp e30. A10, Stock TC. 1.68 60 I think.
Keep us posted
21 Camaro LT1 Fully forged, Katech ported stock heads, P1X,3.7 upper and ATI w/ 8.25 lower, Stage 2 intercooler, Race B.O.V, Btr stage 2 blower cam, Btr Trinity intake, 103mm TB, F.I.C +30’s, Fore innovations, LPE big bore pump, Weld Lagunas Drag Pack. Circle D TC. Full Bmr upgrades, Keltrac rear shocks.
03-03-2023, 02:49 PM | #18 |
Drives: 98 Camaro Join Date: Apr 2022
03-03-2023, 10:09 PM | #19 | |
03-04-2023, 07:30 AM | #20 |
Chris should know this is just a little friendly bantering back and forth. All in fun.
03-04-2023, 08:55 AM | #21 | |
Actually im just sandbagging so you PD guys dont get your feelings hurt too much. Id run a 8.20@235 if i just pressed the gas all the way.
03-04-2023, 09:25 AM | #22 |
My no prep 10.5 @ 137 passes are not even flooring it until 30mph from second gear. That's with the worst PD supercharger on the market according to the internet. Imagine what I could do if I had a Procharger.
Honestly the D1x is one helluva a unit. That is probably what I would go with on a centri setup.
2016 NFG 1SS A8
03-04-2023, 09:54 AM | #23 | |
03-04-2023, 11:12 AM | #24 |
Damn CJ, I knew you were an Aussie! IYKYK
03-04-2023, 01:01 PM | #25 |
That's boostin some boost
03-05-2023, 08:15 AM | #26 |
This raises so many questions. The image I mean.
