01-29-2023, 01:41 PM | #15 |
Drives: 2021 Red Hot ZL1 Join Date: Sep 2020
Less shock on the vehicle drivetrain launching from a dig. Less demand for sticky tires and a prepped track. In some ways its more functional than drag racing since a large part of that is traction limited.
01-29-2023, 03:46 PM | #16 | |
If you dyno at 800 actual hp and the dyno calcs the CF at 1.27, you're corrected power is shown on the dyno sheet as 1016. 1016 times .73 or 73% = 742 actual hp
'20 ZL1 1LE A10,
01-29-2023, 05:09 PM | #17 |
Drives: 2019 Chevy Camaro ZL1 M6 Join Date: Jul 2019
There’s a couple of things that come in to play. First is the correction factor for the elevation. That’s the SAE number. You would be very close to that SAE number if these cars were N/A or turbo. But you’ll actually make more than the SAE on the supercharged car because at sea level you will make 2-3 lbs more of boost. That isnt accounted for in the SAE conversion. And lastly the DA. Sea level gets some fantastic DA and Colorado’s always sucks LOL.
Kong Stage X Port, NW103, LPE HPFP, XDI +30 Injectors, ARH Headers, Flex Fuel, JMS Booster, AWE Touring, Elite E2-X CC. Stock heads, stock cam, stock pulleys: Tuned by KingLT1. 740whp Uncorrected on e50
01-29-2023, 06:24 PM | #18 | |
Drives: 2019 ZL1 Join Date: Oct 2020
01-29-2023, 06:52 PM | #19 | |
01-29-2023, 07:24 PM | #20 |
thanks for the help! and yeah, having bought this car in indy and then driving it out 1000 miles, I certainly know the power difference. Pretty dang crazy!
01-29-2023, 07:31 PM | #21 | |
607 actual hp x 1.22 = 740 corrected hp
'20 ZL1 1LE A10,
OEM short block, LME heads/valve train, E2650. 100+ octanes, no eth, no meth, no N2O. 2/23 - 1031/1004 wheel. 4/23 - 1.41/9.61/145 at DA 7000 ft. (only made five passes). 2/24 - LME 390, E2650, FBO, 100 oct.; 1116hp/ 1063tq; 109 oct. dyno next. Last edited by JSH; 01-29-2023 at 07:51 PM. |
01-29-2023, 08:55 PM | #22 |
01-29-2023, 09:03 PM | #23 |
That's OK. 607 is a good actual hp number.
'20 ZL1 1LE A10,
01-30-2023, 12:04 AM | #24 |
I think so too! Also, even when I'm making 900+ SAE, I'm really only gonna be feeling like mid 700's to the wheel right? So my 325 R888s should be good enough grip on a summer day/night right? I shouldn't need to invest in a drag pack?
01-30-2023, 05:36 AM | #25 | |
Ok, so I found that Camaroking98 did have someone post that dyno sheet for him on the forum, 740.31 hp with env correction of 1.248 is what it said, that is SAE-corrected. Therefore, 593 actual hp is what it was making on that dyno in the Springs on that day. |
01-30-2023, 08:49 AM | #26 | ||
You said:
27% less than 740 can be expressed in two ways: (1) 740 x .27 = 200 - 740 = 540 actual hp, or, (2) 740 x .73 = 540 actual hp My point is, his true or actual hp is not 27% less than the corrected hp on the sheet. Quote:
'20 ZL1 1LE A10,
01-30-2023, 10:56 AM | #27 | |
Drives: 2018 Audi TT RS Join Date: Jan 2014
Now, there's some drag strips that host roll racing events and I think that's fantastic. But, a 60-130 to me, will tell you far more about the car's performance in general, than a 1/4 mile will. It will largely take track prep and traction out of the equation and you're able to see a clearer shot of how the car can power through that range. I'm running mid 4's 60-130 (I don't have a Camaro, sorry) with plenty of room to grow and for the most part, I don't care what many cars can run in the 1/4 mile. The only other metric i care about past that, is their 100-150 time.
2018 Audi TT ▊RS
2.4X 0-60, 1.6X 60', 120+mph 1/8th, 4.XX 60-130, 150+mph traps on 255/35/18 R888R tires on the street (unprepped). 2019 Audi RS3 About as fast as the TT RS 2019 Camaro ZL1 1LE Sold 2018 Camaro SS 1LE Sold 2019 Corvette Z06 Sold 2021 Charger Hellcat Redeye Widebody Sold |
01-30-2023, 02:19 PM | #28 |
Drives: 2017 Chevrolet Camaro ZL1 Join Date: Jul 2018
A fast car will have to be tuned to run a good 60-130 on the street - even with drag radials, and especially with PD blowers like this car comes with. But that same tune would not be optimal if you took it drag racing. So to say it's more functional is not really true because you are changing the vehicle's setup to be better at one or the other. Perhaps it would be true with a mid-9 second or slower car with a good tire, or a little quicker with AWD.
2017 ZL1 - PB 8.05 @ 172 MPH @ 3730 lbs @ 70 DA (work in progress)
Built by Vengeance Racing, tuned by Elite Tuned |
Tags |
60-130, a10, modded |
